I recently bought and tested the NeoPixel Goggles wuth the tutorial and works fine.
But I have a big problem when trying to make it work with the Bluetooth control programm...
The error I have :
Original_avec_bluetooth:13:10: error: SoftwareSerial.h: No such file or directory
13 | #include <SoftwareSerial.h>
compilation terminated.
exit status 1
So Adafruit is selling a kit with a tutorial but it doesn't work...
Do you know what I have to change to make it work ?
// Bluetooth Goggles Sketch -- shows the Adafruit Bluefruit LE UART Friend
// can be used even with Trinket or Gemma!
// https://www.adafruit.com/products/2479
// Works in conjunction with Bluefruit LE Connect app on iOS or Android --
// pick colors or use '1' and '2' buttons to select pinwheel or sparkle modes.
// You can try adding more, but space is VERY tight...helps to use Arduino IDE
// 1.6.4 or later; produces slightly smaller code than the 1.0.X releases.
// BLUEFRUIT LE UART FRIEND MUST BE SWITCHED TO 'UART' MODE
#ifdef __AVR_ATtiny85__ // Trinket, Gemma, etc.
#include <avr/power.h>
#endif
#define RX_PIN 2 // Connect this Trinket pin to BLE 'TXO' pin
#define CTS_PIN 1 // Connect this Trinket pin to BLE 'CTS' pin
#define LED_PIN 0 // Connect NeoPixels to this Trinket pin
#define NUM_LEDS 32 // Two 16-LED NeoPixel rings
#define FPS 30 // Animation frames/second (ish)
SoftwareSerial ser(RX_PIN, -1);
Adafruit_NeoPixel pixels(NUM_LEDS, LED_PIN);
#if defined(__AVR_ATtiny85__) && (F_CPU == 16000000L)
// MUST do this on 16 MHz Trinket for serial & NeoPixels!
clock_prescale_set(clock_div_1);
#endif
// Stop incoming data & init software serial
pinMode(CTS_PIN, OUTPUT); digitalWrite(CTS_PIN, HIGH);
ser.begin(9600);
pixels.begin(); // NeoPixel init
// Flash space is tight on Trinket/Gemma, so setBrightness() is avoided --
// it adds ~200 bytes. Instead the color picker input is 'manually' scaled.
uint8_t buf[3], // Enough for RGB parse; expand if using sensors
animMode = 0, // Current animation mode
animPos = 0; // Current animation position
uint32_t color = 0x400000, // Current animation color (red by default)
prevTime = 0L; // For animation timing
void loop(void) {
int c;
uint32_t t;
// Animation happens at about 30 frames/sec. Rendering frames takes less
// than that, so the idle time is used to monitor incoming serial data.
digitalWrite(CTS_PIN, LOW); // Signal to BLE, OK to send data!
for(;;) {
t = micros(); // Current time
if((t - prevTime) >= (1000000L / FPS)) { // 1/30 sec elapsed?
prevTime = t;
break; // Yes, go update LEDs
} // otherwise...
if((c = ser.read()) == '!') { // Received UART app input?
while((c = ser.read()) < 0); // Yes, wait for command byte
switch(c) {
case 'B': // Button (Control Pad)
if(readAndCheckCRC(255-'!'-'B', buf, 2) & (buf[1] == '1')) {
buttonPress(buf[0]); // Handle button-press message
break;
case 'C': // Color Picker
if(readAndCheckCRC(255-'!'-'C', buf, 3)) {
// As mentioned earlier, setBrightness() was avoided to save space.
// Instead, results from the color picker (in buf[]) are divided
// by 4; essentially equivalent to setBrightness(64). This is to
// improve battery run time (NeoPixels are still plenty bright).
color = pixels.Color(buf[0]/4, buf[1]/4, buf[2]/4);
break;
case 'Q': // Quaternion
skipBytes(17); // 4 floats + CRC (see note below re: parsing)
break;
case 'A': // Accelerometer
#if 0
// The phone sensors are NOT used by this sketch, but this shows how
// they might be read. First, buf[] must be delared large enough for
// the expected data packet (minus header & CRC) -- that's 16 bytes
// for quaternions (above), or 12 bytes for most of the others.
// Second, the first arg to readAndCheckCRC() must be modified to
// match the data type (e.g. 'A' here for accelerometer). Finally,
// values can be directly type-converted to float by using a suitable
// offset into buf[] (e.g. 0, 4, 8, 12) ... it's not used in this
// example because floating-point math uses lots of RAM and code
// space, not suitable for the space-constrained Trinket/Gemma, but
// maybe you're using a Pro Trinket, Teensy, etc.
if(readAndCheckCRC(255-'!'-'A', buf, 12)) {
float x = *(float *)(&buf[0]),
y = *(float *)(&buf[4]),
z = *(float *)(&buf[8]);
// In all likelihood, updates from the buttons and color picker
// alone are infrequent enough that you could do without any mention
// of the CTS pin in this code. It's the extra sensors that really
// start the firehose of data.
break;
#endif
case 'G': // Gyroscope
case 'M': // Magnetometer
case 'L': // Location
skipBytes(13); // 3 floats + CRC
digitalWrite(CTS_PIN, HIGH); // BLE STOP!
// Show pixels calculated on *prior* pass; this ensures more uniform timing
pixels.show();
// Then calculate pixels for *next* frame...
switch(animMode) {
case 0: // Pinwheel mode
for(uint8_t i=0; i<NUM_LEDS/2; i++) {
uint32_t c = 0;
if(((animPos + i) & 7) < 2) c = color; // 4 pixels on...
pixels.setPixelColor( i, c); // First eye
pixels.setPixelColor(NUM_LEDS-1-i, c); // Second eye (flipped)
animPos++;
break;
case 1: // Sparkle mode
pixels.setPixelColor(animPos, 0); // Erase old dot
animPos = random(NUM_LEDS); // Pick a new one
pixels.setPixelColor(animPos, color); // and light it
break;
boolean readAndCheckCRC(uint8_t sum, uint8_t *buf, uint8_t n) {
for(int c;;) {
while((c = ser.read()) < 0); // Wait for next byte
if(!n--) return (c == sum); // If CRC byte, we're done
*buf++ = c; // Else store in buffer
sum -= c; // and accumulate sum
void skipBytes(uint8_t n) {
while(n--) {
while(ser.read() < 0);
void buttonPress(char c) {
pixels.clear(); // Clear pixel data when switching modes (else residue)
switch(c) {
case '1':
animMode = 0; // Switch to pinwheel mode
break;
case '2':
animMode = 1; // Switch to sparkle mode
break;
case '3':
break;
case '4':
break;
case '5': // Up
break;
case '6': // Down
break;
case '7': // Left
break;
case '8': // Right
break;
