Trinket keyboard tutorial
jackv
Post by jackv »
When i tried to compile the program I get the following warning:
In file included from /root/sketchbook/libraries/TrinketKeyboard/usbdrvasm_includer.S:24:
/root/sketchbook/libraries/TrinketKeyboard/usbdrv/usbdrvasm.S:17:1: warning: "__SFR_OFFSET" redefined
In file included from /home/jack/arduino-1.0.5/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../avr/include/avr/io.h:99,
from /root/sketchbook/libraries/TrinketKeyboard/cmdline_defs.h:26,
from /root/sketchbook/libraries/TrinketKeyboard/usbdrvasm_includer.S:22:
/home/jack/arduino-1.0.5/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../avr/include/avr/sfr_defs.h:141:1: warning: this is the location of the previous definition
Binary sketch size: 3,454 bytes (of a 5,310 byte maximum)
I am using Ubuntu 13.04 64 bit.
Thank you
schnee72
Re: Trinket keyboard tutorial
Post by schnee72 »
You are trying to compile as root, you probably don't have the libraries installed in the root's location.
You might find it easier to go ahead and set up your environment to be able to run the arduino ide as your regular user.
I've explained how to communicate with the Trinket as the regular user several posts such as this one:
http://forums.adafruit.com/viewtopic.php?f=52&t=43947
It will involve setting up a custom udev rule.
It isn't usually good to run GUI programs as root, as you can see you get problems such as this one, and even worse.
frank26080115
Post by frank26080115 »
They are just warnings, and these particular warnings are safe to ignore.
I haven't figured out how to get rid of them yet, and it's not a high priority to fix.
jackv
Post by jackv »
The libraries are in /root/sketchbook/libraries, see first line of the message.
The program doesn't run.
schnee72
Post by schnee72 »
I'll stand by the idea that you'll have better luck not running arduino as root.
frank26080115
jackv wrote:The program doesn't run.
Did it enumerate? Can you get some lsusb output?
jackv
Post by jackv »
No, no sign of any output.
Sorry It took so long to get back to you.
jackv
Post by jackv »
twolf - I applied the udev rule so I don't have to be root. It still doesn't work.
