RFM69HCW init fail
RFM69HCW init fail
by uwesan on Tue Oct 10, 2017 3:32 pm
I bought two of the RFM69 breakout boards, and can't get them to initialize on my Arduino Uno. Following the tutorial, I get an Error during compiling:
/home/uwe/sketchbook/libraries/RadioHead/RHHardwareSPI.cpp:109:4: error: #error "Only using transactions in this fork!"
To "fix" this, I downloaded an older Version of the Radiohead library. Now I get an "init fail" error with both of the boards. The modules are working on my Raspberry Pi Zero (perhaps, I only have one, so I can't send a message while listening and vice versa :)
Perhaps it is a stupid beginner's mistake?
#include <SPI.h>
#include <RH_RF69.h>
// Singleton instance of the radio driver
RH_RF69 rf69;
void setup()
  Serial.begin(9600);
  while (!Serial)
  if (!rf69.init())
    Serial.println("init failed");
  if (!rf69.setFrequency(868.0))
    Serial.println("setFrequency failed");
  rf69.setTxPower(14, true);
uwesan
Re: RFM69HCW init fail
by Arudinne on Tue Oct 10, 2017 3:48 pm
What pins did you use? Can you post a picture of the wiring?
Have you tried any of the examples here: https://learn.adafruit.com/adafruit-rfm ... fm69-radio ?
Arudinne
by uwesan on Tue Oct 10, 2017 4:18 pm
I tried to use the Pins shown in the tutorial:
Wiring
And while posting this Image, I found the error: CS has to be on Pin D10 with my Radiohead Version..
Sorry for the inconvenience, I'm still at the very beginning :)
uwesan
by uwesan on Wed Oct 11, 2017 12:26 pm
Hey Again,
I didn't try further yesterday, but now I recognized, that the function rfm69.init() hangs.. All code before that line is executed, but nothing afterwards.. Is it again so easy? :)
#include <SPI.h>
RH_RF69 rf69;
#define RFM69_RST     2
#define RFM69_CS      11
#define RFM69_IRQ     3
#define RFM69_IRQN    RFM69_IRQ
void setup()
  Serial.begin(9600);
  while (!Serial)
  Serial.println("Begin Sketch.");
  pinMode(RFM69_RST, OUTPUT);
  digitalWrite(RFM69_RST, HIGH);
  delay(10);
  digitalWrite(RFM69_RST, LOW);
  delay(10);
  Serial.println("Reset done.");
  if (!rf69.init())
  Serial.println("End Init");
  Serial.println("Frequency set.");
  rf69.setModemConfig(RH_RF69::FSK_Rb9_6Fd19_2);
  rf69.setPreambleLength(3);
  uint8_t syncwords[] = { 0x2d, 0xd4 };
  Serial.println("Config set.");
//  rf69.setSyncWords(syncwords, sizeof(syncwords));
uwesan
by uwesan on Thu Oct 12, 2017 1:37 pm
Hey, update: I know where it hangs, but not why.. :/
spiRead(RH_RF69_REG_27_IRQFLAGS1) always stays 0, so the while-loop never ends. Has somebody an idea?
Following code is from RH_RF69.cpp of the RadioHead library..
void RH_RF69::setOpMode(uint8_t mode)
    Serial.println("Hello, here is setOpMode.");
    uint8_t opmode = spiRead(RH_RF69_REG_01_OPMODE);
    Serial.print("setOpmode read opmode="); Serial.println(opmode);
    opmode &= ~RH_RF69_OPMODE_MODE;
    opmode |= (mode & RH_RF69_OPMODE_MODE);
    Serial.print("Setting opMode to "); Serial.println(opmode);
    spiWrite(RH_RF69_REG_01_OPMODE, opmode);
    Serial.println("setOpMode: spiWrite done.");
    // Wait for mode to change -- or hang...
    while (!(spiRead(RH_RF69_REG_27_IRQFLAGS1) & RH_RF69_IRQFLAGS1_MODEREADY)){
        Serial.print("Waiting for change, "); Serial.print(spiRead(RH_RF69_REG_27_IRQFLAGS1));
        Serial.print(", "); Serial.println(RH_RF69_IRQFLAGS1_MODEREADY);
        delay(500);
uwesan
