Bluetooth streaming
Bluetooth streaming
by Yaronshlomo on Tue Jan 14, 2020 3:29 am
I am looking for a board that can be connected with an android phone and stream music to a speakers, i am also need it to be small as possible and connect to:
https://www.adafruit.com/product/1712
with:
https://www.adafruit.com/product/1669
I will also need small battery with charging module.
please advise.
Yaronshlomo
Re: Bluetooth streaming
by adafruit_support_mike on Wed Jan 15, 2020 6:22 am
BLE can't transmit data fast enough for audio. It maxes out at a few tens of kilobytes per second.
For audio, you need what's now called Bluetooth Classic. Unfortunately BT-C requires a vendor ID that you can only get as a dues-paying member of the Bluetooth Working Group. You pretty much have to scavenge audio Bluetooth hardware from off-the-shelf products.
by Yaronshlomo on Wed Jan 15, 2020 9:28 am
I had no idea, thanks.
Yaronshlomo
by 762spr on Tue Feb 11, 2020 9:56 pm
Check out microchip's BM83 module. I think it will do exactly what you need! (even has built in battery charger!)
762spr
by adafruit_support_mike on Wed Feb 12, 2020 5:58 am
Finding hardware that can do it is no problem. Getting the license (in this case, the VID) to use the hardware is the hard part.
by smcculley on Thu Feb 13, 2020 12:57 am
So, if my intent was to make a phone dialing device that also had a speakerphone (to connect to my iPhone) I'm outta luck?
smcculley
by adafruit_support_mike on Thu Feb 13, 2020 3:37 am
If you want to build it from the ground up and don't feel like handing a few thousand dollars to the BT-WG, yeah.. pretty much. The rules of that product category are written for the benefit of the big players.
The most viable option is to scavenge BT-C hardware from off-the-shelf products and use that as part of a system you've built yourself. There are no laws or rules that prevent hijacking licensed hardware for purposes the manufacturer didn't intend.
