ItsyBitsy nRF52840 Express >100Hz sampling frequency
by sakinsiva on Tue Feb 23, 2021 3:43 am
I am using the Adafruit ItsyBitsy nRF52840 Express module, which samples values from a hall sensor. I programmed it to sample it with 100Hz. When I check the Serial Monitor I can see that it does it correctly. Now I want to send these values through BLE connection to my computer. I use Matlab for reading these values. The sensor values are sent as 2 bytes values over the GATT profile. I can read the values with matlab using the notify-properties from my custom characteristics. But I realised that I only reach a sampling frequency of around 20Hz.
I wanted to ask how I could achieve a better sampling rate? I need atleast 100Hz.
Best regards,
Sakin
sakinsiva
Re: ItsyBitsy nRF52840 Express >100Hz sampling frequency
by mikeysklar on Tue Feb 23, 2021 7:59 pm
Are you using Arduino or CircuitPython on your ItsyBitsy nRF52?
We do have an example of the Feather nRF52 using CircuitPython and claiming 100Hz updates from a finger pulse oximeter. I didn't see any manual override settings in the code, but there might be something that stands out to you:
https://learn.adafruit.com/pulse-oximet ... ter-logger
mikeysklar
