LE Connect - Plotter
by DBBAdafruit on Sat Jul 24, 2021 7:59 pm
Is there any way of changing the time scale for the x-axis? I'd like it to go much slower - on the order of 1 hour per screen rather than the current 90 seconds or so.
Thanks for any response!
Doug
DBBAdafruit
Re: LE Connect - Plotter
by mikeysklar on Mon Jul 26, 2021 7:59 pm
Any difference when changing the value of:
SEND_SECOND_PLOT= 1
or
using autoscroll in landscape mode to display your graph over time
mikeysklar
by DBBAdafruit on Tue Jul 27, 2021 9:44 pm
mikeysklar wrote:Any difference when changing the value of:
SEND_SECOND_PLOT= 1
or
Yes those ideas change the scale but neither allows me to set the scale nor do they allow such a large scale as I want - hours not seconds
DBBAdafruit
by mikeysklar on Wed Jul 28, 2021 4:19 pm
Are you using Android or iOS?
https://github.com/adafruit/Bluefruit_L ... Android_V2
https://github.com/adafruit/Bluefruit_LE_Connect_v2
As the time scale option is not presently avaialble in the Bluefruit LE Connect Apps I would suggest opening an issue for the platform you are on using one of the above links. Being able to set sec/min/hour/days seems reasonable enough.
mikeysklar
