HC-05
HC-05
by DBBAdafruit on Wed Oct 13, 2021 11:07 am
I am not having success using the Feather M0 for BLE projects and have not had any help on the forums and are therefore considering going back to Arduino Uno where there are a lot of example projects. But I cannot seem to find a HC-05 or 06 Bluetooth module for sale. I must be missing it on your website since it is a popular product. Or do you have an equivalent (Bluetooth Classic module for Arduino)?
DBBAdafruit
Re: HC-05
by franklin97355 on Wed Oct 13, 2021 11:59 am
It looks like the modules are available in other places and can be connected to the feather. What are you having trouble with? Perhaps we can help.
franklin97355
Re: HC-05
by adafruit2 on Wed Oct 13, 2021 12:05 pm
we dont stock anything with 'classic anymore. nordic only makes BLE - even espressif is dropping classic in their newer chips
adafruit2
Site Admin
Re: HC-05
by DBBAdafruit on Wed Oct 13, 2021 12:52 pm
franklin97355 wrote:It looks like the modules are available in other places and can be connected to the feather. What are you having trouble with? Perhaps we can help.
Yes, thank you.
I want to display the output of an analog sensor on my smart phone. I know I can use the Bluefruit Connect app to do it, but I would like a more sophisticated interface than it allows. I'd like to use MIT's appinventor program but I need an example of it using a Feather M0. Any examples I've found are for the phone to control the Feather rather than the Feather sending data to the phone. Most other examples are using an Arduino. It should be a rather straight forward process but I have not found one that applies directly and my attempts have so far failed. Do you know of an example or tutorial using a Feather and appinventor to receive analog data?
DBBAdafruit
Re: HC-05
by franklin97355 on Wed Oct 13, 2021 12:59 pm
Can you post a link to a program that you have found that works on the Arduino that will work as you want?
franklin97355
Re: HC-05
by DBBAdafruit on Wed Oct 13, 2021 6:19 pm
franklin97355 wrote:Can you post a link to a program that you have found that works on the Arduino that will work as you want?
I'm not sure if this is what you want - it's my Arduino code that I want to see the output (ie the Serial.print() info) on my phone which would have an App Inventor app installed.
 /*  Rev 1.3    */
  float zeroTank = 6.39;  //560 = 4.5"  720=6.3"
  float tankHeight = 5.1;  //total height of tank
  float totalGal= 39.0 ;  //total capacity of tank
  float maxInch = 8.0;  //calibration point
  int calMin = 128;  //0 pressure at sensor, .5V=102, .75V=153 .63V=128
  int calMax = 895;  //895=8.0"
  float tankZero = 6.3;  //# inches tank bottom is from sensor
  float heightinTank;
// the setup routine runs once when you press reset:
  // initialize serial communication at 9600 bits per second:
  Serial.begin(9600);
// the loop routine runs over and over again forever:
  // read the input on analog pin 0:
  int sensorValue = analogRead(A0);
 /* // Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
  float voltage = sensorValue * (5.0 / 1023.0);
  float absHeight = ((sensorValue-calMin) *maxInch )/(calMax-calMin);
  heightinTank = absHeight-zeroTank;
  if (heightinTank <0) { heightinTank = 0;
  float gallons = heightinTank*totalGal/tankHeight;
  // print out the value you read:
 Serial.print(sensorValue);
 Serial.print(" ");
 Serial.print(voltage);
 Serial.print(" ");
 Serial.print("V   ");
 Serial.print(absHeight);
 Serial.print(" in   ");
 Serial.print(heightinTank);
 Serial.print(gallons);
 Serial.println(" gal  ");
 delay(2000);
if you want a working example similar to what I want including the App Inventor part, that's what I cannot find. Examples using an Arduino instead of the feather use Bluetooth Classic rather than BLE as I would like to use.
DBBAdafruit
Re: HC-05
by DBBAdafruit on Thu Oct 14, 2021 10:39 pm
I have decided to switch back to the Arduino and HC-05 for my project, so please disregard my questions on this topic. The Feather is too specialized for me to start learning Bluetooth. Maybe as I get more comfortable with Bluetooth, I'll try again. Thanks for your help.
DBBAdafruit
Re: HC-05
by DBBAdafruit on Fri Oct 15, 2021 10:26 am
Actually, I just got the attached Arduino and app inventor code that will work on an Arduino/appinventor. Can you instead suggest how I can convert this to Adafruit Feather M0. If I can get something close to what I want, then I can figure it out from there.
ClassicBt_Arduino_ToApp.txt
(1.02 KiB) Downloaded 4 times
https://www.dropbox.com/s/j3217xe1rxfm3k6/BT_Basic_Setup.aia?dl=0
Doug
DBBAdafruit
Re: HC-05
by franklin97355 on Fri Oct 15, 2021 12:30 pm
Sorry, I am not fluent with App Inventor, Perhaps you should ask in their forum or customer support. Can you explain what you want to accomplish in the long run (without software names)?
franklin97355
Re: HC-05
by DBBAdafruit on Fri Oct 15, 2021 9:49 pm
franklin97355 wrote:Sorry, I am not fluent with App Inventor, Perhaps you should ask in their forum or customer support. Can you explain what you want to accomplish in the long run (without software names)?
Thanks for your response. In will wait to get my HC-05 and see if there are still issues - should be a lot easier.
DBBAdafruit
Re: HC-05
by franklin97355 on Fri Oct 15, 2021 10:25 pm
Let us know how it goes.
franklin97355
