Pairing a PS4 Controller to the HUZZAH32
by novi on Mon May 23, 2022 11:01 am
I'm trying to pair a gen 1 PS4 controller to the HUZZAH32 ESP32 Feather. I'm using Arduino IDE. I'm getting no connection and I have no idea why. Also the serial.println under void setup does not show on the serial monitor.
#include <PS4Controller.h>
  Serial.begin(115200);
  Serial.println("Initialization ready!");
  PS4.begin("01:01:01:01:01:01");
//example MAC address
  // put your setup code here, to run once:
  if(PS4.isConnected()) {
    Serial.println("Controller connected");
  delay(1000);
  // put your main code here, to run repeatedly:
novi
Re: Pairing a PS4 Controller to the HUZZAH32
by Franklin97355 on Mon May 23, 2022 11:26 am
You might try
  else {
     Serial.println("Not Connected");
  delay(1000);
to see if the program is cycling.
Which PS4 controller are you using and what library?
Franklin97355
by novi on Mon May 23, 2022 11:42 am
I'm using the dualshock 4 controller with this library I found on GitHub https://github.com/aed3/PS4-esp32
novi
by novi on Mon May 23, 2022 11:45 am
So I tried that code you sent, and the serial monitor repeats:
Not Connected
E (16518) PS4_GAP: ps4_gap_init_service Registering GAP service PS4-HIDC failed
E (16518) PS4_GAP: ps4_gap_init_service Registering GAP service PS4-HIDI failed
What does this mean?
novi
by Franklin97355 on Mon May 23, 2022 1:55 pm
We have not tried connecting to the PS4 but you might contact the author of the software to get help with the PS4.
Franklin97355
by novi on Mon May 23, 2022 2:03 pm
Ok thank you
novi
