BLE Services - Perypethial device documentation
by frangerhawer on Thu Jun 30, 2022 7:17 am
Hello, I cannot find a documentation on how to import BLE Services like i.e. CPS (https://www.bluetooth.com/specifications/specs/) in Circuitpython.
I know which Service and Characteristics I need, but I don't know how to find them in adafruit_ble library.
I found a tutorial hot to do it in C on Arduino: https://teaandtechtime.com/arduino-ble-cycling-power-service/
I want to replicate it using Circuitpython.
Currently, I've only menaged to implement BLE UART service and comunicate my Adafruit Feather nRF52840 Sense with my PC.
frangerhawer
Re: BLE Services - Perypethial device documentation
by mikeysklar on Thu Jun 30, 2022 2:55 pm
I scanned the GitHub repo source code and issues and do not see anything documented on CPS (Cycle Power Service). Would you mind opening an issue requesting CPS implementation?
https://github.com/adafruit/Adafruit_Ci ... BLE/issues
mikeysklar
by frangerhawer on Fri Jul 01, 2022 5:57 am
Are any other GATT Services from the link I provided (https://www.bluetooth.com/specifications/specs/) available in the adafruit_ble library, the same way the UART service is?:
from adafruit_ble.services.nordic import UARTService  <-- change this to i.e. CyclePowerService
I don't know if I should open an issue concerning CPS implementation, or rather about including other GATT Services in the adafruit_ble library.
frangerhawer
by mikeysklar on Fri Jul 01, 2022 6:38 pm
Here are the docs for the adafruit_ble CircuitPython lib. There are some overlapping services (HID, battery, MIDI, etc.) with the Bluetooth link you provided, but the Adafruit library is more general with 'Generic*' service queries.
https://docs.circuitpython.org/projects ... vices.html
While this does not cover CPS there is another Adafruit CircuitPython BLE library.
adafruit_ble_adafruit
Access to sensors and hardware on or connected to BLE-capable boards.
https://docs.circuitpython.org/projects ... it-service
mikeysklar
