#include <SPI.h>
#include <WiFi101.h>
#define CS 6
#define RST 5
#define IRQ 4
char ssid[] = "The Garage"; // your network SSID (name)
char pass[] = "-----"; // your network password
WiFiServer server(23);
int status;
//Configure pins for Adafruit ATWINC1500 Breakout
WiFi.setPins(CS, IRQ, RST);
Serial.begin(9600); while (!Serial);
// check for the presence of the hardware:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
while (true);
// attempt to connect to WiFi network:
status = WL_IDLE_STATUS;
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
status = WiFi.begin(ssid, pass); // Connect.
// wait 10 seconds for connection:
delay(10000);
server.begin(); // start the server:
printWiFiStatus(); // you're connected now, so print out the status:
void printWiFiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
WiFiClient aClient;
char aChar;
aClient = server.available(); // Anyone have data?
if (aClient) { // True means yes I got data.
if (aClient.available()>0) {
while(aClient.available()>0) { // Just like Serial, lets read 'till gone.
aChar = aClient.read(); // Read a byte.
server.write(aChar); // Broadcast it to everyone.
Serial.print(aChar); // Show it on the monitor.
} else {
Serial.print("aClient.available() returns:");Serial.println(aClient.available());
aClient.write("Well hello there!");
Attempting to connect to SSID: The Garage
SSID: The Garage
IP Address: 10.0.1.2
signal strength (RSSI):-75 dBm
aClient.available() returns:0
-jim lee
