Extending Adafruit_BLE Arduino Library
tomegan
Post by tomegan »
Sometimes it is helpful to grab the string(char *) output of an AT command from the BlufruitLE (or other board supported by the Adafruit_BLE library). The library at least version 1.9.5 has support for commands that result in success/failure or an integer but not a string. I personally had a need for the Bluefruit's hardware address which is returned by "AT+BLEGETADDR". My solution was to subclass Adafruit_BluefruitLE_UART which otherwise worked for me and is derived from Adafruit_BLE. My subclass is attached. Usage:
Change:
Adafruit_BluefruitLE_UART ble(BLUEFRUIT_HWSERIAL_NAME, -1);
to:
BB_Bluetooth ble(BLUEFRUIT_HWSERIAL_NAME, -1);
Add:
#define DEVICE_ID_LEN	18
at the top of your code.
Then in your setup or loop code you can use:
char ble_device_id[DEVICE_ID_LEN];
ble.sendCommandWithStringReply(F("AT+BLEGETADDR"), ble_device_id, 18);
and after the code runs, ble_device_id will contain the Bluefruit's hardware address
Bluetooth.cpp
(713 Bytes) Downloaded 57 times
Bluetooth.h
(484 Bytes) Downloaded 51 times
Return to “Wireless: WiFi and Bluetooth”
