NRF8001 not working
NRF8001 not working
by jmac4790 on Wed Jun 12, 2019 10:31 pm
I'm currently trying to get an NRF8001 BLE module to send voltage readings from the analog pins of an Arduino Nano to an android device. I am unable to get the NRF8001 to advertise using the code I have written. The code is getting stuck on the blePeripheral.begin(); line. I am having the same issue with the example sketches as well as with sketches found online. I have bought and tested using a second NRF8001 module as well as another Arduino Nano and Arduino Uno with no luck. Previously this code has been working fine but now it is not advertising hence why i suspected i had broken my original NRF8001 module and tested it using a new one. I have included my sketch below. I'm relatively new to this so it is possible I have missed something. Any help would be much appreciated.
#include <MemoryFree.h>
#include <BLEPeripheral.h>
#include <Wire.h>
#include<SPI.h>
#define BLE_REQ 10
#define BLE_RDY 2
#define BLE_RST 9
BLEPeripheral blePeripheral = BLEPeripheral(BLE_REQ,BLE_RDY,BLE_RST);
BLEService Service = BLEService("DDD0");
BLECharacteristic Characteristic = BLEFixedLengthCharacteristic("DDD1", BLERead | BLEWrite | BLENotify,12);
unsigned long previousMillis = millis();    //Stores the last time sensor was read
unsigned long interval = 10000;         //Interval between sensor readings
void setup()
  Serial.begin(9600);
  Serial.println(Service.uuid());
  Serial.println(Characteristic.uuid());
  Serial.println(F("Bluetooth Low Energy Sensor Reader"));
  blePeripheral.setLocalName("Pressure Reader");
  blePeripheral.setDeviceName("Pressure Reader");
  Serial.println(F("Local name and device name set to Pressure Reader"));
  blePeripheral.setAdvertisedServiceUuid(Service.uuid());
  blePeripheral.addAttribute(Service);
  blePeripheral.addAttribute(Characteristic);
  Characteristic.setValue(0);
  Serial.print(F("freeMemory()="));
  Serial.println(freeMemory());
  Serial.println(F("1234"));
  Serial.println(F("blePeripheral.begin() worked"));
void loop()
  blePeripheral.poll();
  if (millis() - previousMillis >= interval)
    pollSensors();
void pollSensors()
  union {
    float f;
    byte bytes[4];
  } floatUnion;
  union {
    float f;
    byte bytes[4];
  } floatUnion2;
  union {
    float f;
    byte bytes[4];
  } floatUnion3;
  float voltage1 = analogRead(A0);
  float pressure1 = voltage1*5/1023;      //Change for correct calibration
  floatUnion.f = pressure1;
  float voltage2 = analogRead(A0);
  float pressure2 = voltage2*2*5/1023;    //Change for correct calibration
  floatUnion2.f = pressure2;
  float voltage3 = analogRead(A0);
  float pressure3 = voltage3*3*5/1023;    //Change for correct calibration
  floatUnion3.f = pressure3;
  byte byteArr[12];
  int ii = 0;
  for(ii= 0 ; ii < 12 ; ii ++ ){
    if(ii<4){
      //pressure1
      byteArr[ii] = floatUnion.bytes[ii];
    }else if((ii>=4)&&(ii<8)){
      //pressure2
      byteArr[ii] = floatUnion2.bytes[ii-4];
    }else if((ii>=8)&&(ii<12)){
      //pressure3
      byteArr[ii] = floatUnion3.bytes[ii-8];
 Characteristic.setValue(byteArr,12);
    Serial.print(F("Pressure 1: "));
    Serial.println(pressure1);
    Serial.println(pressure2);
    Serial.println(pressure3);
jmac4790
Re: NRF8001 not working
by siddacious on Fri Jun 14, 2019 2:29 pm
Hi jmac4790,
Please help us help you by posting pictures that allow us to clearly see your wiring so we can determine how things are connected.
siddacious
by jmac4790 on Mon Jun 17, 2019 9:37 pm
The connections are
Arduino Nano>>NRF8001
Vin>>Vin
GND>>GND
D2>>RDY
D9>>RST
D10>>REQ
D11>>MOSI
D12>>MISO
jmac4790
