teeny weeny RF connector
by fishesfromtupperware on Tue Feb 18, 2020 3:38 pm
I'd like use an external antenna on my osmo pocket wifi module. I've found what looks like tiny rf plugs at the ends of the what appears to be antennas. A quick interweb search turned up an MHF4, but it looks too big. Are they standard or proprietary?
20200218_105318 - Edited.jpg (137.66 KiB) Viewed 37 times
The blue circled areas are the terminals. The arrow is pointing to one that's missing from this version.
20200218_110130 - Edited.jpg (140.86 KiB) Viewed 37 times
The last pic is a detail of a terminal.
20200216_235137 (1) - Edited.jpg (55.71 KiB) Viewed 37 times
Is this a job for : SMA to uFL/u.FL/IPX/IPEX RF Adapter Cable PRODUCT ID: 851 ?
Re: teeny weeny RF connector
by fishesfromtupperware on Tue Feb 18, 2020 8:45 pm
After poking around a bit more I found this ;
https://www.i-pex.com/sites/default/fil ... SW18_E.pdf
Its a "1.8 x 1.8 mm excellent inspection connector <switch> for RF modules with on-board antennas". Appears to be more of a switched test probe port than a connector. When a probe is inserted, the antenna is switched out of the circuit. Great! Now if just gotta find a probe.
Do yall have a adapter cable similar to parts 851/852 thats smaller (MHF5?) with a male connector? Plug diameter is 1.2 (mm?)
