HUZZAH ESB8266 won't come online
Re: HUZZAH ESB8266 won't come online
by adafruit_support_carter on Fri Feb 28, 2020 12:51 pm
Do you have another machine you could test the cable on?
by NCRookie on Sun Mar 01, 2020 2:17 pm
I don't have one on which I can install the drivers
NCRookie
by adafruit2 on Tue Mar 03, 2020 11:22 am
ok unplug the cable, shutdown the computer, wait a few minutes (this may help reset the USB port if a polyfuse blew), reboot the computer
then plug the cable in, and in terminal check & paste the output of
ls /dev/cu*
adafruit2
Site Admin
by NCRookie on Tue Mar 03, 2020 1:15 pm
The Mac reboot did the trick with the cable - I can now see and upload to the 8266. However, I am back to my original problem - the non-responding 8266. I was able to upload the Blink code from the above page successfully, but it doesn't blink - the red LED is lit continuously - nothing is blinking.
NCRookie
by adafruit2 on Tue Mar 03, 2020 1:18 pm
press reset button on the esp
adafruit2
Site Admin
by NCRookie on Tue Mar 03, 2020 2:34 pm
Forgot about having to reset to get it out of bootloader mode. It blinked so I went onto the second test - bringing up WiFi. After uploading and resetting, I watched the serial monitor. I got a message that it was connecting to my SSID and then an endless row of periods put out by this section of code
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
The SSID and password are correct
NCRookie
by adafruit2 on Tue Mar 03, 2020 2:38 pm
ok sounds like your hardware is running now - check out tutorials online on progamming the ESP, if you can program it, its likely just a software bug in your sketch :)
adafruit2
Site Admin
by NCRookie on Tue Mar 03, 2020 8:02 pm
I used the example code from your website. The board is non-functional as a WiFi device, It needs to be replaced≥
NCRookie
by adafruit2 on Tue Mar 03, 2020 8:51 pm
try an example where you create an access point AND also try an example where you scan wifi AP's
adafruit2
Site Admin
by NCRookie on Tue Mar 03, 2020 10:37 pm
Do you have the code for that?
NCRookie
by adafruit2 on Tue Mar 03, 2020 11:10 pm
i googled for "esp8266 wifi scan" and such, did not try but some stuff like this came up
https://arduino-esp8266.readthedocs.io/ ... mples.html
adafruit2
Site Admin
by NCRookie on Wed Mar 04, 2020 11:17 am
Discovered an error in the SSID and got it working. Thanks
NCRookie
