Raspberry Pi 3 - Wifi Hotspot not detected
by devonn on Sat Sep 19, 2020 12:59 pm
I purchased my raspberry pi 3 model B on Friday, September 4, 2020 (Invoice No. 235864) (Order ID: P01-0422558-9821050 through Amazon pay).
When my package got delivered, I was sad to see that the boxes containing the board and the power supply were both badly damaged from the shipping process (see attached photos).
I was going to use this raspberry pi to run astroprint for my 3D printer, so I figured I might as well try to see if it was still functioning. After trying many different methods from astroprint's main website and reading many forums, I could not find the wifi hotspot anywhere on any of my other devices. I can connect it through ethernet, but all connection is lost when attempting to setup the wifi connection.
Since the Astroprint setup is very simple and straight forward to do with a pre-flashed sd card, I find it very hard to believe that I made an error in the 3 step process: inserting the pre-flashed drive into the slot, inserting the correct wifi dongle for the hotspot, and connecting to the astroprint through wifi on any device.
TLDR: I assume that the board has a defective wifi hotspot/connection, but let me know if there is anything that I could have missed in the setup process.
I appreciate the help. Thank you!
devonn
Re: Raspberry Pi 3 - Wifi Hotspot not detected
by mikeysklar on Mon Sep 21, 2020 12:06 pm
Hi Devonn,
Do you have an external WiFi dongle that is Pi compatible? I ask because looking at the AstroPrint site they seem to encourage an external WiFi be used with the Pi 3.
https://blog.astroprint.com/astroprint- ... 3-support/
Regardless, if you would like us to replace the Pi we can make that arrangement. Although I would ask you to load a copy of the latest PiOS just to confirm the WiFi is not appearing.
https://www.raspberrypi.org/downloads/raspberry-pi-os/
mikeysklar
by devonn on Tue Sep 22, 2020 12:03 pm
Would I just have to install the OS and check if there is a wifi signal, or would I have to download a script editor as well?
devonn
by devonn on Tue Sep 22, 2020 8:05 pm
After installing the new OS, the wifi situation has not changed.
devonn
by mikeysklar on Wed Sep 23, 2020 12:36 pm
Okay, let's swap it out.
Please send an e-mail to support@adafruit.com
Require a replacement for your Pi 3. Include your order# and a link to this forum thread.
mikeysklar
