🔮Adafruit sale all weekend long – use the code ADATHX for 15% off! 🔮
ItsyBitsy nRF52840 - Powering
by rwgreen1173 on Fri Oct 16, 2020 3:03 pm
I am using the ItsyBitsy nRF52840 to scan for a bluetooth device.
When it runs plugged into a usb power source it works fine.
Then when I try to power it with a battery on the BAT and GND pin it turns on and after a little while it turns off.
Am I missing something obvious.
Maybe the board is trying to conserve battery and turning off?
rwgreen1173
Re: ItsyBitsy nRF52840 - Powering
by dastels on Fri Oct 16, 2020 4:17 pm
What are you using for a battery?
dastels
by rwgreen1173 on Fri Oct 16, 2020 4:41 pm
I have tried quite a few things most recently a 3.7 Li-ion.
rwgreen1173
by dastels on Fri Oct 16, 2020 5:43 pm
Does it shut down like this only when it's doing specific things, or does it always?
dastels
by rwgreen1173 on Fri Oct 16, 2020 5:50 pm
It is scanning for a bluetooth device all the time.
Nothing else. It just turns off after a little while.
I am thinking maybe its is going into low power mode ?
rwgreen1173
by dastels on Fri Oct 16, 2020 6:04 pm
Not unless your code is putting in a low power mode. Is the battery drained?
dastels
by rwgreen1173 on Mon Oct 19, 2020 12:10 pm
No.
If I unplug it and plug it back in it turns back on for a while again.
rwgreen1173
by dastels on Mon Oct 19, 2020 12:30 pm
I'm baffled. I'll reach out to see if I can find anything useful.
dastels
by adafruit2 on Mon Oct 19, 2020 12:39 pm
please post a photo showing your setup, including battery, wiring, and charger
adafruit2
Site Admin
by rwgreen1173 on Wed Oct 21, 2020 8:13 am
rwgreen1173
by adafruit2 on Wed Oct 21, 2020 11:07 am
nothing looks amiss - the power is a simple diode input, so power is the 'same' from battery or USB - like there's no magical thing different about USB power. when the 'itsy' turns off do you see any LEDs at all?
you could maybe try another battery?
adafruit2
Site Admin
by rwgreen1173 on Thu Oct 22, 2020 5:01 pm
Ok,
Something must be wrong because now it's not even powering on at all.
rwgreen1173
