🔮Adafruit sale all weekend long – use the code ADATHX for 15% off! 🔮
Bluefruit Connect shows only the Info module
by nico_ on Sat Oct 17, 2020 6:07 pm
Hi all! Brand new to bluetooth.
I have the ItsyBitsy nRF52840 Express with BLE and have uploaded the example controller.ino sketch from the intro guide.
When I connect to the board using the Bluefruit app (v3.3.2 on Android 10) I can see only the Info module, and can't see the controller, location, color picker, etc.
It seems as if this has happened to someone else, but their problem seems to have resolved itself on re-connecting. I've had no such luck after re-uploading, restarting the phone, etc.
Looking at the part of the Bluefruit Connect source which populates the Modules menu, it seems like this should only happen if neither DFU nor UART are reported as services. The app indicates that UART is available when connecting, so I'm not sure what's going on.
Thanks for any help!
Screenshots and Serial Monitor output below.
15:27:00.096 -> Adafruit Bluefruit52 Controller App Example
15:27:00.096 -> -------------------------------------------
15:27:00.096 -> [CFG   ] SoftDevice's RAM requires: 0x20002D30
15:27:00.096 -> Please use Adafruit Bluefruit LE app to connect in Controller mode
15:27:00.096 -> Then activate/use the sensors, color picker, game controller, etc!
15:27:00.096 ->
15:27:00.096 ->
15:27:00.096 -> BSP Library : 0.21.0
15:27:00.096 -> Bootloader  : s140 6.1.1
15:27:00.096 -> Serial No   : B6BEB46530D27834
15:27:00.096 ->
15:27:00.096 -> --------- SoftDevice Config ---------
15:27:00.096 -> Max UUID128     : 10
15:27:00.096 -> ATTR Table Size : 4096
15:27:00.096 -> Service Changed : 1
15:27:00.096 -> Peripheral Connect Setting
15:27:00.096 ->   - Max MTU         : 23
15:27:00.096 ->   - Event Length    : 3
15:27:00.096 ->   - HVN Queue Size  : 1
15:27:00.096 ->   - WrCmd Queue Size: 1
15:27:00.096 ->
15:27:00.096 -> --------- BLE Settings ---------
15:27:00.096 -> Name            : Bluefruit52
15:27:00.096 -> Max Connections : Peripheral = 1, Central = 0
15:27:00.096 -> Address         : E9:F3:31:47:EC:6D (Static)
15:27:00.096 -> TX Power        : 4 dBm
15:27:00.096 -> Conn Intervals  : min = 20.00 ms, max = 30.00 ms
15:27:00.096 -> Conn Timeout    : 2000 ms
15:27:00.096 -> Peripheral Paired Devices:
15:27:00.096 ->   5f5e : Galaxy S9 (92 bytes)
15:27:00.096 ->
15:27:00.096 ->
15:27:06.520 -> [BLE   ] BLE_GAP_EVT_CONNECTED : Conn Handle = 0
15:27:06.520 -> [GAP   ] Conn Interval= 47.50 ms, Latency = 0, Supervisor Timeout = 5000 ms
15:27:06.709 -> [BLE   ] BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST : Conn Handle = 0
15:27:06.709 -> [GAP   ] ATT MTU is changed to 23
15:27:07.177 -> [BLE   ] BLE_GAP_EVT_CONN_PARAM_UPDATE : Conn Handle = 0
15:27:07.177 -> [GAP   ] Conn Interval= 23.75 ms, Latency = 0, Supervisor Timeout = 2000 ms
15:27:07.269 -> [BLE   ] BLE_GAP_EVT_SEC_INFO_REQUEST : Conn Handle = 0
15:27:07.269 -> [BOND  ] Loaded keys from file /adafruit/bond_prph/5f5e
15:27:07.362 -> [BLE   ] BLE_GAP_EVT_CONN_SEC_UPDATE : Conn Handle = 0
15:27:07.362 -> [BOND  ] CCCD setting not found
Initially:
After connecting:
Info module:
nico_
Re: Bluefruit Connect shows only the Info module
by collinmel on Fri Oct 23, 2020 2:59 pm
Hey nico - I was able to test the code on nRF52832 w Android, but I don't have an 840 on hand to try. You could try hathach's suggestions in this thread:
https://github.com/adafruit/Adafruit_nR ... issues/580
Commenting out line 34 to remove the Serial delay is definitely worth a shot:
while ( !Serial ) delay(10);
collinmel
