Bluetooth enabled display
by MRosich on Sat Nov 07, 2020 11:41 am
Hi. I saw on one of Adafruit videos a bluetooth cycling senor display. I searched and could not find any other type of bluetooth/display projects. I am looking to create a small display, similar to the size of the cycling display able to receive data from a pressure sensor and display it on the LCD or LED via bluetooth. Right now the display is attached to the circuit board but I would like to transmit the data via bluetooth to a small display instead. I am simply inquiring if this is possible and if so, what hardware would I need to purchase to make this work. I will get assistance with any of the coding and circuit connections to make it work since this is not my area of expertise. Thank you in advance for your help. Mike
MRosich
Re: Bluetooth enabled display
by blnkjns on Sat Nov 07, 2020 3:50 pm
Atom Core or Atom Stick? Small IPS display with ESP32 and bluetooth for not much more as most separate displays.
blnkjns
