Feather BLE broadcast to raspberry pi
by mossyoak1101 on Thu Jan 21, 2021 1:33 am
I need some help before I loose my mind!
I have a Feather nRF52840 Express with an i2c temperature sensor connected. I am trying to broadcast the data from the sensor to a Raspberry Pi 3A+.
The code on the Feather is this
import time
import board
import busio
import adafruit_mcp9808
import adafruit_ble_broadcastnet
i2c_bus = busio.I2C(board.SCL, board.SDA)
mcp = adafruit_mcp9808.MCP9808(i2c_bus)
print("This is BroadcastNet Feather sensor:", adafruit_ble_broadcastnet.device_address)
while True:
    measurement = adafruit_ble_broadcastnet.AdafruitSensorMeasurement()
    measurement.temperature = mcp.temperature
    print(measurement)
    adafruit_ble_broadcastnet.broadcast(measurement)
    time.sleep(60)
I am using the ble_broadcastnet_blinka_bridge.py example from github on the raspberry pi. I followed this tutorial line for line.
https://learn.adafruit.com/bluetooth-le ... LMQAvD_BwE
When I run the code on the Feather, It prints out the measurement data as expected to the console window.
This is BroadcastNet Feather sensor: f681590b3b1d
<AdafruitSensorMeasurement temperature=22.3125 >
When I run the code on the raspberry pi it acts like it is scanning but I get nothing.
This is BroadcastNet bridge: b827eb97b11e
Fetching existing feeds.
scanning
I can't seem to figure out what I am doing wrong. Any help or suggestions would be greatly appreciated.
mossyoak1101
Re: Feather BLE broadcast to raspberry pi
by mossyoak1101 on Thu Jan 21, 2021 1:50 am
If it helps at all I was able to see the raw data using a Bluetooth scanner app.
mossyoak1101
by mossyoak1101 on Thu Jan 21, 2021 10:06 pm
In trying to do some more testing, I was able to get this tutorial to work.
https://learn.adafruit.com/circuitpytho ... rt-example
Communication seems to work fine between the feather and the pi. It seems only when I am trying to use the broadcastnet to broadcast the sensor data from the feather to the pi that I can't see the data.
mossyoak1101
by mossyoak1101 on Fri Jan 22, 2021 1:43 am
Still trying to do more trouble shooting. I attempted the same tutorial for the broadcastnet, but this time broadcasting to a pi zero w.
Still same results. I can see the feather is sending the data but nothing is seen by the raspberry pi.
I must be missing something. I even tried another time and had my wife help make sure I was doing everything line for line, and still the same result. I really want this to work but I'm running out of ideas...
mossyoak1101
