Loop doen't seem to run
by johnlavik on Tue Jan 26, 2021 6:24 pm
I am playing with the Feather M0 RFM695's. When I first got them, I ran the examples (RadioHead69_RawDemo_TX & RX) and things worked. Then, after making some changes to the code, it seemed like the setup() would run, but the loop() would not. So, I reinstalled the example sketch, and the loop still won't run. Any ideas what might be wrong?
I think this is unrelated, but it seems like the port changes unexpectedly... sometimes it is COM11, then it switches to COM8 or COM10, and then back to COM11, like something about resetting the board confuses the computer about which COM port the chip is connected to.
Here is the most recent code I tried (and it is the same as the example except for the frequency:
// rf69 demo tx rx.pde
// -*- mode: C++ -*-
// Example sketch showing how to create a simple messageing client
// with the RH_RF69 class. RH_RF69 class does not provide for addressing or
// reliability, so you should only use RH_RF69  if you do not need the higher
// level messaging abilities.
// It is designed to work with the other example rf69_server.
// Demonstrates the use of AES encryption, setting the frequency and modem
// configuration
#include <SPI.h>
#include <RH_RF69.h>
/************ Radio Setup ***************/
// Change to 434.0 or other frequency, must match RX's freq!
#define RF69_FREQ 433.0
#if defined (__AVR_ATmega32U4__) // Feather 32u4 w/Radio
  #define RFM69_CS      8
  #define RFM69_INT     7
  #define RFM69_RST     4
  #define LED           13
#endif
#if defined(ADAFRUIT_FEATHER_M0) // Feather M0 w/Radio
  #define RFM69_CS      8
  #define RFM69_INT     3
  #define RFM69_RST     4
  #define LED           13
#endif
#if defined (__AVR_ATmega328P__)  // Feather 328P w/wing
  #define RFM69_INT     3  //
  #define RFM69_CS      4  //
  #define RFM69_RST     2  // "A"
  #define LED           13
#endif
#if defined(ESP8266)    // ESP8266 feather w/wing
  #define RFM69_CS      2    // "E"
  #define RFM69_IRQ     15   // "B"
  #define RFM69_RST     16   // "D"
  #define LED           0
#endif
#if defined(ESP32)    // ESP32 feather w/wing
  #define RFM69_RST     13   // same as LED
  #define RFM69_CS      33   // "B"
  #define RFM69_INT     27   // "A"
  #define LED           13
#endif
/* Teensy 3.x w/wing
#define RFM69_RST     9   // "A"
#define RFM69_CS      10   // "B"
#define RFM69_IRQ     4    // "C"
#define RFM69_IRQN    digitalPinToInterrupt(RFM69_IRQ )
/* WICED Feather w/wing
#define RFM69_RST     PA4     // "A"
#define RFM69_CS      PB4     // "B"
#define RFM69_IRQ     PA15    // "C"
#define RFM69_IRQN    RFM69_IRQ
// Singleton instance of the radio driver
RH_RF69 rf69(RFM69_CS, RFM69_INT);
int16_t packetnum = 0;  // packet counter, we increment per xmission
void setup()
  Serial.begin(115200);
  //while (!Serial) { delay(1); } // wait until serial console is open, remove if not tethered to computer
  pinMode(LED, OUTPUT);
  pinMode(RFM69_RST, OUTPUT);
  digitalWrite(RFM69_RST, LOW);
  Serial.println("Feather RFM69 RX Test!");
  Serial.println();
  // manual reset
  digitalWrite(RFM69_RST, HIGH);
  delay(10);
  delay(10);
  if (!rf69.init()) {
    Serial.println("RFM69 radio init failed");
    while (1);
  Serial.println("RFM69 radio init OK!");
  // Defaults after init are 434.0MHz, modulation GFSK_Rb250Fd250, +13dbM (for low power module)
  // No encryption
  if (!rf69.setFrequency(RF69_FREQ)) {
    Serial.println("setFrequency failed");
  // If you are using a high power RF69 eg RFM69HW, you *must* set a Tx power with the
  // ishighpowermodule flag set like this:
  rf69.setTxPower(20, true);  // range from 14-20 for power, 2nd arg must be true for 69HCW
  // The encryption key has to be the same as the one in the server
  uint8_t key[] = { 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08,
                    0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08};
  rf69.setEncryptionKey(key);
  Serial.print("RFM69 radio @");  Serial.print((int)RF69_FREQ);  Serial.println(" MHz");
 if (rf69.available()) {
    // Should be a message for us now
    uint8_t buf[RH_RF69_MAX_MESSAGE_LEN];
    uint8_t len = sizeof(buf);
    if (rf69.recv(buf, &len)) {
      if (!len) return;
      buf[len] = 0;
      Serial.print("Received [");
      Serial.print(len);
      Serial.print("]: ");
      Serial.println((char*)buf);
      Serial.print("RSSI: ");
      Serial.println(rf69.lastRssi(), DEC);
      if (strstr((char *)buf, "Hello World")) {
        // Send a reply!
        uint8_t data[] = "And hello back to you";
        rf69.send(data, sizeof(data));
        rf69.waitPacketSent();
        Serial.println("Sent a reply");
        Blink(LED, 40, 3); //blink LED 3 times, 40ms between blinks
    } else {
      Serial.println("Receive failed");
void Blink(byte PIN, byte DELAY_MS, byte loops) {
  for (byte i=0; i<loops; i++)  {
    digitalWrite(PIN,HIGH);
    delay(DELAY_MS);
    digitalWrite(PIN,LOW);
    delay(DELAY_MS);
johnlavik
Re: Loop doen't seem to run
by mikeysklar on Wed Jan 27, 2021 5:49 pm
What are you seeing in the Arduino IDE Serial monitor?
mikeysklar
by johnlavik on Fri Jan 29, 2021 11:20 am
OK... I've really been struggling to get it to upload code to one of my two boards (my "receiver" board.) I have no idea why it only seems to connect and upload 1 out of 10 times I try. Once I finally succeed, I get the following on the serial monitor.
RFM69 radio @433 MHz
But it never serial prints any of the lines from the loop.
Here is the sketch I am using:
// configuration
#include <SPI.h>
  #define RFM69_CS      8
  #define RFM69_INT     7
  #define RFM69_RST     4
  #define LED           13
#endif
  #define RFM69_CS      8
  #define RFM69_INT     3
  #define RFM69_RST     4
  #define LED           13
#endif
  #define LED           13
#endif
  #define LED           0
#endif
  #define LED           13
#endif
void setup()
  Serial.println();
  // manual reset
  delay(10);
  delay(10);
  if (!rf69.init()) {
    while (1);
  // No encryption
      if (!len) return;
      buf[len] = 0;
      Serial.print(len);
        // Send a reply!
    } else {
johnlavik
by johnlavik on Fri Jan 29, 2021 11:31 am
Partial success... I have finally gotten the two boards talking again. Unfortunately, I don't really know what I did different that allowed it to work, except I have the transmit sketch running on another machine. I would have expected to get "failed to receive" messages.
OH!! But now that I look closely at the sketch, I see that it only gives that message if it receives a transmission and fails to decode it. So I think it was working before, but since I didn't have the transmitter going, my receiver appeared to be "dead".
I still don't know why it is so hard to upload code to my one board.
johnlavik
by mikeysklar on Fri Jan 29, 2021 1:19 pm
Are you pressing the reset button and toggling into bootloader mode during code uploads?
Are you using the same USB cable and USB port when uploading to both boards?
mikeysklar
by johnlavik on Sat Jan 30, 2021 10:56 am
Is it required to press reset button in order to upload code? I have done that sometimes, but I don't think I do it every time. (I have not paid rigorous attention to when I do and when I don't.) I think I read that a "double press" of the reset button enters bootloader mode, but it seemed like that wasn't always necessary.
Also, it seems like whenever I enter bootloader mode, the board switches to a different port #. Then the upload fails because it can't find the port. I switch it back to the previous port and then it succeeds in uploading. (e.g. normally it is connected to Port 11. When I double press reset button, I look at the port setting and it appears to be on Port 10, so I switch to Port 10. It allows me to start the upload, but it doesn't complete and says "can't find port". I then look at port setting and it shows as being connected to Port 11 again, so I select that and then the upload will succeed.
All this is (I think) just an annoyance and not a problem. Just time consuming.
johnlavik
by mikeysklar on Sun Jan 31, 2021 5:31 pm
@johnlavik,
You will have to press the reset button to upload code.
mikeysklar
