Wifi101 firmware Update Fails-Programmer not responding
Re: Wifi101 firmware Update Fails-Programmer not responding
by Pishi64 on Thu Feb 04, 2021 8:53 pm
mikeysklar wrote:Pishi64,
Would love to see your CoViD project in with display and network. Post here when you get things going.
Mike,
Would like to do that when it's finished.
Mike a bit of update. I carefully followed the instruction and here is how my setup and connections look like:
When I run the Firmwareversion checker: It can not find the shield (Shield not Found).
Few points here:
    On the Wifi shield I see both CLK and SCL--(i) SCL to Mega or (ii) CLK to Mega 52 produced the same error
I'm not sure which one should be connected to Mega 52!!
    With multimeter I checked every single connection--All working with tiny impedance.
    When I press the reset button on shield I see no response being produced by the Mega board
    When I assemble the shield on top of the Mega board I can check the firmware with no issues.
    I added this code to the sketch too
WiFi.setPins(8,7,4);
Any thoughts?
Pishi64
by mikeysklar on Fri Feb 05, 2021 3:40 pm
Wiring looks good. I assume those connections are soldered on the shield side?
The WINC1500 CLK <--> Mega p52
To be clear this is the three pins on the shield you are interested in connecting with for SPI:
Is your brown wire connected to the breadboard positive rail from the mega 5v or 3v? I can't quite make that out in the photo.
mikeysklar
by Pishi64 on Fri Feb 05, 2021 6:21 pm
mikeysklar wrote:Wiring looks good. I assume those connections are soldered on the shield side?
The connections are not soldered on the shield side as I wanted to make sure of the connections first. The short brown wire is connected to the 5v.
Pishi64
by Pishi64 on Fri Feb 05, 2021 8:32 pm
Update: I soldered the connections on the shield side but still I get the "Shield Not Found" error.
Pishi64
by mikeysklar on Mon Feb 08, 2021 3:13 pm
@pishi64,
I am seeing references to the ICSP header on the WINC1500 needing to connect to the mega 2560 to make things work in addition to the pin changes we discussed.
https://forum.atmosphereiot.com/t/devic ... und/328/18
I bought the shield, and it plugs right into the Mega board. I did have to add the ICSP header, it wouldn’t work AT ALL without it.
Now, it’s better, it picked up the WINC1500. However, it wouldn’t let me add network settings (said something like “some settings are not applicable” in red print), and I can’t figure out how to get back in to try again
Also interesting they are using 3.3v instead 5v in this example.
 Arduino      WINC1500
Pin 5   =>   RST
Pin 7   =>    IRQ
Pin 10   =>    CS
3.3V   =>   VIN
3.3V   =>   EN
3.3V   =>    CFG
GND   =>    GND
Pin 51   =>    MOSI
Pin 50   =>    MISO
Pin 52   =>    SCK
mikeysklar
by Pishi64 on Wed Feb 10, 2021 7:50 pm
mikeysklar wrote:@pishi64,
 Arduino      WINC1500
Pin 5   =>   RST
Pin 7   =>    IRQ
Pin 10   =>    CS
3.3V   =>   VIN
3.3V   =>   EN
3.3V   =>    CFG
GND   =>    GND
Pin 51   =>    MOSI
Pin 50   =>    MISO
Pin 52   =>    SCK
Thanks Mike,
Couple of questions:
    I don't see CFG n the wifi shield !, where is that one?
    I need to attach the ICSP header as well? with all these wires already attached? Should I get femal-to-male wires?
BTW, I have ordered an authentic Arduino Mega!:D
Pishi64
by mikeysklar on Thu Feb 11, 2021 11:57 am
The ICSP connector is already populated with male headers on the mega. You would be soldering a female header to 2x3 size to connect into on the underside of the WiFi shield.
I would have encouraged you to not use another Mega and use an Arduino UNO or Metro for this shield as those are what we have the most experience with. Regardless I'm sure you will get it going.
You can ignore the CFG pin. I don't see it either, but looking at our pinouts page for the WINC1500 we recommend not connecting it:
CFG - allows you to select between SPI (default) or UART data transport. Since we don't have any UART code, keep disconnected
https://learn.adafruit.com/adafruit-atw ... ut/pinouts
mikeysklar
by Pishi64 on Thu Feb 11, 2021 2:31 pm
mikeysklar wrote:The ICSP connector is already populated with male headers on the mega. You would be soldering a female header to 2x3 size to connect into on the underside of the WiFi shield.
Thanks again Mike,
I need to choose an alternative board that can run both WifiShield and the Adafruit's RGBScreen shield. Any suggestion?
Pishi64
by mikeysklar on Fri Feb 12, 2021 2:54 pm
The Arduino UNO would be the most straight forward to get going as it is used in both guide pages for the WiFi shield and RGB LCD shield.
The Metro M4 express would have a lot more memory and CPU performance which could make for a more enjoyable process while having an Arduino UNO like pinout so not being so different than the example wiring.
https://www.adafruit.com/product/3382
Maybe play it safe and buy one of each?
mikeysklar
by Pishi64 on Fri Feb 12, 2021 7:24 pm
mikeysklar wrote:The Arduino UNO would be the most straight forward to get going as it is used in both guide pages for the WiFi shield and RGB LCD shield.
Mike,
I had this Metro board in my wish list just in case kind of backup. Now that you brought it up, I decided to give it a try. I have UNO which didn't help with their low memory and performance. I'll try the Mega and this new Metro and will keep you updated.
Thanks again!
Pishi64
by Pishi64 on Thu Mar 18, 2021 8:07 pm
Hi Mike,
I bought the Metro M4 express and still I can't update the firmware. I get the same error: Programmer is not responding. Any idea how to fix this?
Pishi64
by mikeysklar on Fri Mar 19, 2021 1:13 pm
Okay, glad you got a Metro M4.
How are you connecting your shield are you plugging it into the Metro M4 or are you manually wiring it? If wiring please post a photo.
Are you seeing serial output on the console? Can you provide that here?
What firmware version is currently detected?
mikeysklar
by Pishi64 on Fri Mar 19, 2021 8:11 pm
mikeysklar wrote:Okay, glad you got a Metro M4.
I'm using Arduino IDE 1.8.13 (on Mac) and when I run the Wifi101's check firmware version I get the below message:
Screen Shot 2021-03-19 at 7.53.24 PM.jpg (186.2 KiB) Viewed 119 times
I am plugging the wifi shield directly on top of the M4 express. When I run the firmware updater, I get the error message:
Screen Shot 2021-03-19 at 8.05.44 PM.png (992.77 KiB) Viewed 119 times
Screen Shot 2021-03-19 at 8.06.31 PM.png (639.6 KiB) Viewed 119 times
I can switch to CircuitPython, but I already have the sketch for what I need on IDE.
Pishi64
by mikeysklar on Mon Mar 22, 2021 5:49 pm
Searching around the only time I see the same error with the Programmer not responding during a WiFi101 update is due to the "WiFiNINA by Arduino" library not being installed through the Arduino IDE.
Is that the case here?
https://forum.arduino.cc/index.php?topic=632352.0
mikeysklar
by Pishi64 on Tue Mar 30, 2021 6:58 pm
mikeysklar wrote:Searching around the only time I see the same error with the Programmer not responding during a WiFi101 update is due to the "WiFiNINA by Arduino" library not being installed through the Arduino IDE.
Mike,
It didn't work! I got whole bunch of errors like this one wen I ran the check firmware version sketch
Arduino: 1.8.13 (Mac OS X), Board: "Adafruit Metro M4 (SAMD51), Enabled, 120 MHz (standard), Small (-Os) (standard), 50 MHz (standard), TinyUSB, Off"
/Users/x/Documents/Arduino/libraries/WiFiNINA/src/utility/spi_drv.cpp: In static member function 'static void SpiDrv::begin()':
/Users/x/Documents/Arduino/libraries/WiFiNINA/src/utility/spi_drv.cpp:108:15: error: 'NINA_GPIO0' was not declared in this scope; did you mean 'NINA_GPIOIRQ'?
108 | pinMode(NINA_GPIO0, OUTPUT);
| NINA_GPIOIRQ
/Users/x/Documents/Arduino/libraries/WiFiNINA/src/utility/spi_drv.cpp: In static member function 'static int SpiDrv::available()':
/Users/x/Documents/Arduino/libraries/WiFiNINA/src/utility/spi_drv.cpp:65:25: error: 'NINA_GPIO0' was not declared in this scope; did you mean 'NINA_GPIOIRQ'?
65 | #define NINA_GPIOIRQ NINA_GPIO0
/Users/x/Documents/Arduino/libraries/WiFiNINA/src/utility/spi_drv.cpp:602:25: note: in expansion of macro 'NINA_GPIOIRQ'
602 | return (digitalRead(NINA_GPIOIRQ) != LOW);
Multiple libraries were found for "Adafruit_ZeroDMA.h"
Used: /Users/x/Library/Arduino15/packages/adafruit/hardware/samd/1.6.6/libraries/Adafruit_ZeroDMA
Not used: /Users/arash/Documents/Arduino/libraries/Adafruit_Zero_DMA_Library
exit status 1
Error compiling for board Adafruit Metro M4 (SAMD51).
I guess I need to try the Circuitpython and get the program going in there. I was not expecting to get this level of complications. what do you think?
Pishi64
