RFM69HCW file transmission
by sashaT on Wed Mar 03, 2021 11:02 pm
Hi all,
Is it possible to stream at 1-5 fps low quality video from the RFM69HCW modules? I wanted to have the arduino capture the image, write it onto the sd card and then convert it into binary/base64 and then send it to be decoded. I was wondering, is it possible to this more efficiently?
sashaT
Re: RFM69HCW file transmission
by adafruit_support_mike on Thu Mar 04, 2021 12:00 am
Probably not. The RFM69's bitrate is 19.2kbps, which translates to about 2.3 kilobytes.
by sashaT on Thu Mar 04, 2021 11:38 am
Then is it possible to record an mp4, then send it to the computer?
sashaT
by adafruit_support_mike on Thu Mar 04, 2021 11:49 pm
Yes. The RadioHead library has a reliable transmission option that you can use to transmit large pieces of data like files. You'll need to break the file into smaller chunks on the transmitter and reassemble them on the receiver.
I can't promise that the data will arrive at real-time rates though, even with compression.
by sashaT on Fri Mar 05, 2021 10:06 am
Thank you! Though I can't seem to find the module. Would you please list it?
sashaT
by adafruit_support_mike on Fri Mar 05, 2021 8:09 pm
Take a look at the 'reliable datagram' example sketches that come with the RadioHead library:
https://github.com/adafruit/RadioHead/t ... mples/rf69
