LE SPI Friend issues
by gebov on Mon Apr 05, 2021 4:41 am
I am trying to use the LE SPI friend. My firmware version is 0.6.5. I tried updating the firmware version because I am struggling with connection issues and thought that might help but every time I try to update, it gets to 43% and fails with the error message DFU Service disconnected. Is that a problem with the Android APP or the module ?
As for the connectivity issues I am hooking it up to a S32K144 dev board from NXP with FLEXIO. However I have failed so far to achieve anything using the samples provided by NXP. I will try with a different MCU as well to confirm if everything is OK with the communication. For now the board seems to answer to the AT commands from the Android APP.
gebov
Re: LE SPI Friend issues
by adafruit_support_carter on Tue Apr 06, 2021 3:22 pm
Do you have a board available that would allow you to use the BLE SPI Friend per the guide?
https://learn.adafruit.com/introducing- ... i-breakout
by gebov on Mon Apr 12, 2021 7:11 am
No sadly, I conducted numerous tests following the guide here https://learn.adafruit.com/introducing- ... -transport
And inspecting the source code for the Arduino module. I am receiving some strange bytes when I send the following message: 0x10 0x01 0x0A 0x01 0xFF which are never consistent - 0x80, 0x7F 0xFF, 0xFE. Some of these are error codes but I cannot see what I am doing wrong. Here is my code. I have based it on the arduiono code in github. I've left comments for reference
PTB->PSOR |= 1<<17; // bring CS high
for(i = 0; i < 4000; i++) // wait a bit
PTB->PCOR |= 1<<17; // bring CS low
while(1)
LPSPI1_transmit_16bits(buffer[0]); // transmit 0x10
LPSPI1_16bits_read = LPSPI1_receive_16bits(); // wait for the reply
if (LPSPI1_16bits_read != 0xFE)
break;
for(i = 1; i < 4; i++)
LPSPI1_transmit_16bits(buffer[i]); // transmit the rest of the bytes
PTB->PSOR |= 1<<17; // set CS high again
I cannot neither receive nor sent any proper response in the Android App. I am starting to think that this board is defective.
gebov
by adafruit_support_carter on Mon Apr 12, 2021 10:37 am
You would need to find some way to verify the behavior by using it per the guide. It may have something to do with FLEXIO.
by gebov on Thu May 27, 2021 3:56 pm
I succeeded in communicating with the SPI module with a different board than the Arduino.
The question that I now have is that I am successfully able to send the commands AT, ATI AT+HELP from my board to the Adafruit SPI module(and recieve the proper responses), but any other command results in ERROR \n response text. The command I am testing is AT+GATDEVNAME.
Other at commands are resulting in error as welll. My board revision is 0.6.5.
gebov
by adafruit_support_carter on Thu May 27, 2021 4:09 pm
Where are you finding reference to that command?
by gebov on Thu May 27, 2021 8:44 pm
Sorry, I misspelled it here in the forum. The name is AT+GAPDEVNAME
https://learn.adafruit.com/introducing- ... -2176685-8
gebov
by gebov on Thu May 27, 2021 8:50 pm
I should mention that the same AT command (AT+GAPDEVNAME) works through the mobile app after sending +++.
gebov
by adafruit_support_carter on Fri May 28, 2021 10:29 am
That's the mode switching command:
https://learn.adafruit.com/introducing- ... 2176540-11
So for the errors you are getting with the other AT commands, maybe you are in the wrong mode there also?
by gebov on Fri May 28, 2021 1:40 pm
Actually the AT commands that work do not require a context switch from data to command mode. They just work without me sending the +++ command from my board. They +++ command is required from the mobile app only.
The other strange thing is that when I send +++ from the mobile app i get a response "1 OK" or "0 OK" for entering and exiting command mode respectively. Whereas from my board when sending +++ I always recieve an "OK" and the command itself does not mae a difference for the AT commands that do not work.
gebov
by adafruit_support_carter on Fri May 28, 2021 2:27 pm
Are you still using flexio?
by gebov on Fri May 28, 2021 11:31 pm
No, i am no longer using the s32k144 board either. I have a HCS12 mcu that is currently hooked with the SPI port.
I am attaching my code here for reference. My code is based on the code that was provided in github for the arduino.
As you can see I initially attempt to send the at command for reading the device name(atCommandSetDeviceName). It does not matter if i use it in read mode or write mode. The result is the same - i recieve "ERROR".
Placing the command AT or ATI in the place of atCommandSetDeviceName works fine and returns "OK" and the device info respectively. I even tried initially sending +++ before i send any AT command but there is no effect. And like I said, the AT and ATI commands work fine without sending the +++ command
main.c
(6.9 KiB) Downloaded 3 times
gebov
by adafruit_support_carter on Tue Jun 01, 2021 11:36 am
It may be something with your C code? We can only support usage per the product guide.
