Client BLEService does not detect 128 bit Custom UUID
by jaja_adf on Tue Apr 06, 2021 6:19 am
- I'm working with Adafruit Feather nRF52840 to make client that connect to multiple server and then streming data to my client !
- I succeeded to compile Centrale_custom_hrm / Custom_hrm arduino example with two Adafruit Feather nRF52840 board, all the example use SIG UUID with 16bit.
- I try to change code to use custom UUID with 128bit for Centrale_custom_hrm example , i can compile it without error, but the central didn't detect advertising of the server, i use android application to emulate Server GAT, i show you below my code :
Centrale_custom_hrm :
#include <bluefruit.h>
/* Xsens Service Definitions
 * Heart Rate Monitor Service:  0x180D
 * Heart Rate Measurement Char: 0x2A37 (Mandatory)
 * Body Sensor Location Char:   0x2A38 (Optional)
const uint8_t UUID128_SVC_XSENS[] =
    0x80, 0x70, 0x80, 0x70, 0x80, 0x00, 0x00, 0x80,
    0x00, 0x10, 0x00, 0x00, 0xF0, 0xFF, 0x00, 0x00
const uint8_t UUID128_CHR_XSENS[] =
    0x00, 0x10, 0x00, 0x00, 0xF1, 0xFF, 0x00, 0x00
BLEClientService        xsens_svc(UUID128_SVC_XSENS);
BLEClientCharacteristic xsens_chr(UUID128_CHR_XSENS);
//BLEClientService        hrms(UUID16_SVC_HEART_RATE);
//BLEClientCharacteristic hrmc(UUID16_CHR_HEART_RATE_MEASUREMENT);
//BLEClientCharacteristic bslc(UUID16_CHR_BODY_SENSOR_LOCATION);
void setup()
  Serial.begin(115200);
  while ( !Serial ) delay(10);
  Bluefruit.begin(0, 1);
  Bluefruit.setName("Central");
  // Initialize HRM client
  //hrms.begin();
  xsens_svc.begin();
  xsens_chr.setNotifyCallback(hrm_notify_callback);
  xsens_chr.begin();
  Bluefruit.setConnLedInterval(250);
  Bluefruit.Central.setDisconnectCallback(disconnect_callback);
  Bluefruit.Central.setConnectCallback(connect_callback);
  Bluefruit.Scanner.setRxCallback(scan_callback);
  Bluefruit.Scanner.restartOnDisconnect(true);
  Bluefruit.Scanner.setInterval(160, 80); // in unit of 0.625 ms
  Bluefruit.Scanner.filterUuid(xsens_svc.uuid);
  Bluefruit.Scanner.useActiveScan(false);
  Bluefruit.Scanner.start(0);
void loop()
  // do nothing
void scan_callback(ble_gap_evt_adv_report_t* report)
  Bluefruit.Central.connect(report);
void connect_callback(uint16_t conn_handle)
  Serial.println("Connected");
  Serial.print("Discovering HRM Service ... ");
  // If HRM is not found, disconnect and return
  if ( !xsens_svc.discover(conn_handle) )
    Serial.println("Found NONE");
    // disconnect since we couldn't find HRM service
    Bluefruit.disconnect(conn_handle);
    return;
  // Once HRM service is found, we continue to discover its characteristic
  Serial.println("Found it");
  Serial.print("Discovering Measurement characteristic ... ");
  if ( !hrmc.discover() )
    // Measurement chr is mandatory, if it is not found (valid), then disconnect
    Serial.println("not found !!!");
    Serial.println("Measurement characteristic is mandatory but not found");
    return;
  // Reaching here means we are ready to go, let's enable notification on measurement chr
  if ( xsens_chr.enableNotify() )
    Serial.println("Ready to receive HRM Measurement value");
  }else
    Serial.println("Couldn't enable notify for HRM Measurement. Increase DEBUG LEVEL for troubleshooting");
void disconnect_callback(uint16_t conn_handle, uint8_t reason)
  (void) conn_handle;
  (void) reason;
  Serial.print("Disconnected, reason = 0x"); Serial.println(reason, HEX);
void hrm_notify_callback(BLEClientCharacteristic* chr, uint8_t* data, uint16_t len)
  Serial.print("HRM Measurement: ");
  if ( data[0] & bit(0) )
    uint16_t value;
    memcpy(&value, data+1, 2);
    Serial.println(value);
  else
    Serial.println(data[1]);
I Maybe miss somthing when i cutomised the UUID, Can some one help me with this ? thanks.
Bests regards,
JAJA
BLE SERVER.jpg (103.7 KiB) Viewed 55 times
jaja_adf
