Feather Huzzah w/ ESP8266 Questions
by doctorwho8 on Tue Apr 06, 2021 9:33 am
Hello!
I picked up a Feather Huzzah with ESP8266 from Microcenter last week. It's the one shown in the Adafruit site as https://www.adafruit.com/product/2821 . I had hoped to make use of it via the serial connections on it, to become a serial to WiFi communications device, to add functionality to older devices. To that end I chose to try out the example in the Arduino IDE for connecting the thing to WiFi and serial to telnet. Which looks like this:
  WiFiTelnetToSerial - Example Transparent UART to Telnet Server for esp8266
#include <ESP8266WiFi.h>
#include <algorithm> // std::min
#ifndef STASSID
#define STASSID "your-ssid"
#define STAPSK  "your-password"
#endif
    SWAP_PINS:
   0: use Serial1 for logging (legacy example)
   1: configure Hardware Serial port on RX:GPIO13 TX:GPIO15
      and use SoftwareSerial for logging on
      standard Serial pins RX:GPIO3 and TX:GPIO1
#define SWAP_PINS 0
    SERIAL_LOOPBACK
    0: normal serial operations
    1: RX-TX are internally connected (loopback)
#define SERIAL_LOOPBACK 0
#define BAUD_SERIAL 115200
#define BAUD_LOGGER 115200
#define RXBUFFERSIZE 1024
#if SERIAL_LOOPBACK
#undef BAUD_SERIAL
#define BAUD_SERIAL 3000000
#include <esp8266_peri.h>
#endif
#if SWAP_PINS
#include <SoftwareSerial.h>
SoftwareSerial* logger = nullptr;
#else
#define logger (&Serial1)
#endif
#define STACK_PROTECTOR  512 // bytes
//how many clients should be able to telnet to this ESP8266
#define MAX_SRV_CLIENTS 2
const char* ssid = STASSID;
const char* password = STAPSK;
const int port = 23;
WiFiServer server(port);
WiFiClient serverClients[MAX_SRV_CLIENTS];
  Serial.begin(BAUD_SERIAL);
  Serial.setRxBufferSize(RXBUFFERSIZE);
#if SWAP_PINS
  Serial.swap();
  // Hardware serial is now on RX:GPIO13 TX:GPIO15
  // use SoftwareSerial on regular RX(3)/TX(1) for logging
  logger = new SoftwareSerial(3, 1);
  logger->begin(BAUD_LOGGER);
  logger->enableIntTx(false);
  logger->println("\n\nUsing SoftwareSerial for logging");
#else
  logger->println("\n\nUsing Serial1 for logging");
#endif
  logger->println(ESP.getFullVersion());
  logger->printf("Serial baud: %d (8n1: %d KB/s)\n", BAUD_SERIAL, BAUD_SERIAL * 8 / 10 / 1024);
  logger->printf("Serial receive buffer size: %d bytes\n", RXBUFFERSIZE);
#if SERIAL_LOOPBACK
  USC0(0) |= (1 << UCLBE); // incomplete HardwareSerial API
  logger->println("Serial Internal Loopback enabled");
#endif
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  logger->print("\nConnecting to ");
  logger->println(ssid);
  while (WiFi.status() != WL_CONNECTED) {
    logger->print('.');
    delay(500);
  logger->println();
  logger->print("connected, address=");
  logger->println(WiFi.localIP());
  //start server
  server.begin();
  server.setNoDelay(true);
  logger->print("Ready! Use 'telnet ");
  logger->print(WiFi.localIP());
  logger->printf(" %d' to connect\n", port);
  //check if there are any new clients
  if (server.hasClient()) {
    //find free/disconnected spot
    int i;
    for (i = 0; i < MAX_SRV_CLIENTS; i++)
      if (!serverClients[i]) { // equivalent to !serverClients[i].connected()
        serverClients[i] = server.available();
        logger->print("New client: index ");
        logger->print(i);
        break;
    //no free/disconnected spot so reject
    if (i == MAX_SRV_CLIENTS) {
      server.available().println("busy");
      // hints: server.available() is a WiFiClient with short-term scope
      // when out of scope, a WiFiClient will
      // - flush() - all data will be sent
      // - stop() - automatically too
      logger->printf("server is busy with %d active connections\n", MAX_SRV_CLIENTS);
  //check TCP clients for data
#if 1
  // Incredibly, this code is faster than the bufferred one below - #4620 is needed
  // loopback/3000000baud average 348KB/s
  for (int i = 0; i < MAX_SRV_CLIENTS; i++)
    while (serverClients[i].available() && Serial.availableForWrite() > 0) {
      // working char by char is not very efficient
      Serial.write(serverClients[i].read());
#else
  // loopback/3000000baud average: 312KB/s
      size_t maxToSerial = std::min(serverClients[i].available(), Serial.availableForWrite());
      maxToSerial = std::min(maxToSerial, (size_t)STACK_PROTECTOR);
      uint8_t buf[maxToSerial];
      size_t tcp_got = serverClients[i].read(buf, maxToSerial);
      size_t serial_sent = Serial.write(buf, tcp_got);
      if (serial_sent != maxToSerial) {
        logger->printf("len mismatch: available:%zd tcp-read:%zd serial-write:%zd\n", maxToSerial, tcp_got, serial_sent);
#endif
  // determine maximum output size "fair TCP use"
  // client.availableForWrite() returns 0 when !client.connected()
  size_t maxToTcp = 0;
    if (serverClients[i]) {
      size_t afw = serverClients[i].availableForWrite();
      if (afw) {
        if (!maxToTcp) {
          maxToTcp = afw;
        } else {
          maxToTcp = std::min(maxToTcp, afw);
      } else {
        // warn but ignore congested clients
        logger->println("one client is congested");
  //check UART for data
  size_t len = std::min((size_t)Serial.available(), maxToTcp);
  len = std::min(len, (size_t)STACK_PROTECTOR);
  if (len) {
    uint8_t sbuf[len];
    size_t serial_got = Serial.readBytes(sbuf, len);
    // push UART data to all connected telnet clients
      // if client.availableForWrite() was 0 (congested)
      // and increased since then,
      // ensure write space is sufficient:
      if (serverClients[i].availableForWrite() >= serial_got) {
        size_t tcp_sent = serverClients[i].write(sbuf, serial_got);
        if (tcp_sent != len) {
          logger->printf("len mismatch: available:%zd serial-read:%zd tcp-write:%zd\n", len, serial_got, tcp_sent);
And I discovered that the code works via the telnet client on the host for example connected to the WiFi on the Feather, and showed me the text entered via the telnet client on the logging screen.
Which is a good demo of the device, but I'm looking for a functions which work both ways.
doctorwho8
