Adding Flora LE Bluefruit to Gemma M0
by dondoc1 on Thu May 27, 2021 9:31 pm
I've been working to add special functionality to a NeoPixel Jewel attached to a Gemma M0. The project was a success but now I'm being asked to add the Flora LE to the project. I noticed that the Gemma has RX and TX options but I'm not sure how to merge the bluetooth feature to this project. I've search for some time for Gemma and Flora LE hoping for some sample code for adding this to the Gemma, No luck so far. Any assistance would really be appreciated.
dondoc1
Re: Adding Flora LE Bluefruit to Gemma M0
by adafruit_support_mike on Fri May 28, 2021 10:24 pm
The Gemma M0's Serial connection works the same way as the Flora's. The code from the tutorial should work without any modification:
https://learn.adafruit.com/adafruit-flo ... ample-code
by dondoc1 on Sun May 30, 2021 10:56 pm
adafruit_support_mike wrote:The Gemma M0's Serial connection works the same way as the Flora's. The code from the tutorial should work without any modification:
thx. I'll try the code minus a few lines as suggested. Again, thanks.
dondoc1
