Control UNO with Feather nRF52 Bluefruit?
scotch1
Post by scotch1 »
Looking to use the nRF52 Bluefruit to control the PWM input to an UNO input (to be read by another program which has an UNO firmata on it to read it).
Have the controller working ok per this: https://learn.adafruit.com/bluefruit-nr ... controller
Like the example that has the nRF52 dimming the LEDhttps://learn.adafruit.com/bluefruit-le-connect/pin-i-o, would like to do that + put the valiues into an UNO to be read.
Trying to follow this guide: https://learn.adafruit.com/bluefruit-le ... and-config but am confused on the changes and uncomments needed for the nRF52 I have:
/************************  CONFIGURATION SECTION ***********************************/
Don't forget to also change the BluefruitConfig.h for the SPI or UART connection
and pinout you are using!
Then below, you can edit the list of pins that are available. Remove any pins
that are used for accessories or for talking to the BLE module!
/************** For Bluefruit Micro or Feather 32u4 Bluefruit ************/
uint8_t boards_digitaliopins[] = {0,1,2,3,5,6,9,10,11,12,13,A0,A1,A2,A3,A4,A5};
/************** For UNO + nRF58122 SPI & shield ************/
//uint8_t boards_digitaliopins[] = {2, 3, 5, 6, 9, 10, A0, A1, A2, A3, A4, A5};
/************** For Bluefruit M0 Bluefruit ************/
//uint8_t boards_digitaliopins[] = {0,1,5,6,9,10,11,12,13,20,21,A0,A1,A2,A3,A4,A5};
and in the configh.h file:
DO i need to chanmge to transmit/control an UNO?
// SOFTWARE UART SETTINGS
// The following macros declare the pins that will be used for 'SW' serial.
// You should use this option if you are connecting the UART Friend to an UNO
#define BLUEFRUIT_SWUART_RXD_PIN       9    // Required for software serial!
#define BLUEFRUIT_SWUART_TXD_PIN       10   // Required for software serial!
#define BLUEFRUIT_UART_CTS_PIN         11   // Required for software serial!
#define BLUEFRUIT_UART_RTS_PIN         -1   // Optional, set to -1 if unused
scotch1
Re: Control UNO with Feather nRF52 Bluefruit?
Post by scotch1 »
A simpler Question:
What settings does the nRF52 require? ARM Cortex M4F
Technical: https://learn.adafruit.com/bluefruit-nr ... troduction
The Wiring options seem to suggest the Micro 32u4 or Feather M0
https://learn.adafruit.com/bluefruit-le ... ng-options
Following this approach for Firmata: https://learn.adafruit.com/bluefruit-nr ... le-pin-i-o leads to https://github.com/adafruit/Adafruit_nR ... FirmataBLE, uploading turns it off and the Iphone app doesn't see it.
Followed this: https://learn.adafruit.com/bluefruit-le ... and-config
Gets errors:
'boards_analogiopins' was not declared in this scope
THe controller sketch works but can't do I/O and PWM.
Tried the "StandardFirmataBLE" Firmata for nRF52 boards: not seen on iphone. Code loaded.
scotch1
Post by scotch1 »
Follwed the guide to rerun th ebootloader, and updated to 0.24.
Sketches seem to work EXCEPT the StandardFirmataBLE:
Error seems to indicate multiple libraries. Saw a 0.21.0 under nrf52 and deleted it so only 0.24.0 exists.
Error reports:
In file included from C:\Users\micha\AppData\Local\Arduino15\packages\adafruit\hardware\nrf52\0.24.0\libraries\Bluefruit52Lib\examples\Peripheral\StandardFirmataBLE\StandardFirmataBLE.ino:31:
C:\Program Files (x86)\Arduino\libraries\Firmata/Firmata.h:131:17: error: friend declaration of 'void encodeByteStream(size_t, uint8_t*, size_t) const' specifies default arguments and isn't a definition [-fpermissive]
  131 |     friend void FirmataMarshaller::encodeByteStream (size_t bytec, uint8_t * bytev, size_t max_bytes = 0) const;
Multiple libraries were found for "Servo.h"
 Used: C:\Users\micha\AppData\Local\Arduino15\packages\adafruit\hardware\nrf52\0.24.0\libraries\Servo
 Not used: C:\Program
Multiple libraries were found for "Wire.h"
 Used: C:\Users\micha\AppData\Local\Arduino15\packages\adafruit\hardware\nrf52\0.24.0\libraries\Wire
Multiple libraries were found for "Firmata.h"
 Used: C:\Program
Multiple libraries were found for "Adafruit_LittleFS.h"
 Used: C:\Users\micha\AppData\Local\Arduino15\packages\adafruit\hardware\nrf52\0.24.0\libraries\Adafruit_LittleFS
Multiple libraries were found for "InternalFileSystem.h"
 Used: C:\Users\micha\AppData\Local\Arduino15\packages\adafruit\hardware\nrf52\0.24.0\libraries\InternalFileSytem
Multiple libraries were found for "bluefruit.h"
 Used: C:\Users\micha\AppData\Local\Arduino15\packages\adafruit\hardware\nrf52\0.24.0\libraries\Bluefruit52Lib
Multiple libraries were found for "Adafruit_TinyUSB.h"
 Used: C:\Users\micha\AppData\Local\Arduino15\packages\adafruit\hardware\nrf52\0.24.0\libraries\Adafruit_TinyUSB_Arduino
exit status 1
Error compiling for board Adafruit Feather nRF52832.
Found a nRF52831 library: Deleted it. Same error on running the STandardFirmataBLE.
Something is not right with this Sketch...https://learn.adafruit.com/bluefruit-nr ... le-pin-i-o
Can you provide guidance?
scotch1
Post by scotch1 »
THe neopixel sketch works.
THe Firmata is not working, from here: https://learn.adafruit.com/bluefruit-nr ... le-pin-i-o
COpied from here: https://github.com/adafruit/Adafruit_nR ... ataBLE.ino
Error:
Arduino: 1.8.10 (Windows 10), Board: "Adafruit Feather nRF52832, S132 6.1.1, Level 0 (Release)"
In file included from D:\My_Docs_Master\Arduino_OldComp\Michael_test_codes\BluFruitTestCodes\firmata_try_again\firmata_try_again.ino:25:
 Used: C:\Program
exit status 1
hathach
Post by hathach »
it is an issue of firmata library https://github.com/adafruit/Adafruit_nR ... -727751057 . They fix it in the upstream but haven't released it yet (only affect some port which unfortunately include our nrf52 core). For walkaround, you could download their git master (zip) and extra to your library to build.
It is indeed issue with firmata library, it is fixed in their upstream https://github.com/firmata/arduino/blob/master/Firmata.h#L131 here. But it is not released just yet, I have no control when they release 2.5.9 , maybe you could just download their current master.zip and extract to the libraries folder.
scotch1
Post by scotch1 »
That link is to a Firmata.h file only.
If I could find a similar file to replace I would, however, in that Adafruit BLEFirmata folder, there are no similar files unless the example needs to be changed?
Saving it as a Firmata.h or ino file doesn't seem to work.
WHat github package and is that manage libraries with a zip file install? Can't find the file they mention.
Any guidance?
hathach
Post by hathach »
here is the github repo of firmata project https://github.com/firmata/arduino , just click code button and download it as zip file and replace/copy to your library as Arduino/libraries/firmata .
Screenshot from 2021-07-31 11-50-22.png (53.13 KiB) Viewed 525 times
Adafruit_BLEFirmata is for nrf51 only, and has nothing do with nrf52.
scotch1
Post by scotch1 »
Followed the link: https://github.com/firmata/arduino
Followed the instructions:
COntroller works fine.
StandardFirmataBLE same issue.
C:\Users\micha\Documents\Arduino\libraries\Firmata/Firmata.h:131:17: error: friend declaration of 'void encodeByteStream(size_t, uint8_t*, size_t) const' specifies default arguments and isn't a definition [-fpermissive]
 Used: C:\Users\micha\Documents\Arduino\libraries\Firmata
 Not used: C:\Users\micha\Documents\Arduino\libraries\arduino-master
exit status 1
Also tried to install as a downloaded zip as Arduino-master.zip.
Looked for example StandardFirmataBLE from the "FIRMATA" library and different error:
In file included from C:\Users\micha\Documents\Arduino\libraries\arduino-master\examples\StandardFirmataBLE\StandardFirmataBLE.ino:28:
C:\Users\micha\Documents\Arduino\libraries\arduino-master\examples\StandardFirmataBLE\StandardFirmataBLE.ino: In function 'void setup()':
StandardFirmataBLE:772:3: error: 'stream' was not declared in this scope; did you mean 'Stream'?
  772 |   stream.setLocalName(FIRMATA_BLE_LOCAL_NAME);
      |   Stream
C:\Users\micha\Documents\Arduino\libraries\arduino-master\examples\StandardFirmataBLE\StandardFirmataBLE.ino: In function 'void loop()':
StandardFirmataBLE:806:8: error: 'stream' was not declared in this scope; did you mean 'Stream'?
  806 |   if (!stream.poll()) return;
      |        Stream
exit status 1
'stream' was not declared?..
Tried replacing all 'stream' with 'Stream', then got expected unqualified-id before '.' token....
Still not able to run.
scotch1
Post by scotch1 »
Curious if the updates to this example https://learn.adafruit.com/bluefruit-nr ... le-pin-i-o solved the issues with the firmata?
scotch1
Post by scotch1 »
Tried the Firmatahttps://github.com/adafruit/Adafruit_nR ... FirmataBLE: Failed on compile. So, not updated, it appears.
hathach
Post by hathach »
scotch1 wrote:Tried the Firmatahttps://github.com/adafruit/Adafruit_nR ... FirmataBLE: Failed on compile. So, not updated, it appears.
You run the correct example, however, the bug is within the firmata library itself. Check out my above comment, here is what you need to do to build that example
goto https://github.com/firmata/arduino , just click code button and download it as zip file and replace/copy to your library as Arduino/libraries/firmata .
scotch1
Post by scotch1 »
SO the issue is that the folder downloaded is 'Arduino-Master':
And needs to replaces the "Firmata" folder;
C:\Users\xxxxx\Documents\Arduino\libraries\Firmata
Appears to compile and work. Nice
Return to “Wireless: WiFi and Bluetooth”
