I have tried many, many times to get my Zero W connected to my wifi. I have used the RPI Imager to image the Lite OS. I have created the wpa_supplicant.conf and ssh files using a text editor. I put the card in the Pi, power it up, the green light flashes for a while and ends up solid after a couple minutes. I try the "ping -c 3 raspberrypi.local" in terminal on my mac and I always get "ping: cannot resolve raspberrypi.local: Unknown host".
I am stuck at this point. No idea what to do. I have tried the above steps, reimaged every single time, to no avail. I cannot get it on the wifi. I have checked that my ssid and password are correct and have the quotation marks around them. Still can't get on the wifi. Any help would so appreciated. Thank you.
Cannot Connect to WiFi
- Franklin97355
Re: Cannot Connect to WiFi
Does your router use security and did you configure it? Can you log into your router and see if it is communicating with the pi?
- jbishko
My router does use security and I put the password to my wifi in the wpa_supplicant.conf file. Below is what I put in the file:
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
country=US
network={
ssid="myssid"
psk="myrouterpassword"
scan_ssid=1
I can log into my router and I do not see the pi there. No idea what to do.
update_config=1
country=US
network={
ssid="myssid"
scan_ssid=1
- jbishko
Soooo....using a different sd card that what was sent along with the app Espresso instead of the native mac text app, all is good!!!!!!
- Franklin97355
Great, glad it's working.
