I am attempting to use your pi zero wh on a mmdvm hotspot. The configuration file ask me to select the modem from a dropdown menu. Do you have a suggestion as to which one I should use?
This is the dropdown menu:
Icom Repeater Controller ID-RP2C (DStarRepeater Only)
DVMEGA Raspberry Pi Hat (GPIO) - Single Band (70cm)
DVMEGA Raspberry Pi Hat (GPIO) - Dual Band
DVMEGA on Arduino (USB - /dev/ttyUSB0) - Dual Band
DVMEGA on Arduino (USB - /dev/ttyACM0) - Dual Band
DVMEGA on Arduino (USB - /dev/ttyUSB0) - GMSK Modem
DVMEGA on Arduino (USB - /dev/ttyACM0) - GMSK Modem
DVMEGA on Bluestack - Single Band (70cm)
DVMEGA on Bluestack - Dual Band
GMSK Modem (USB DStarRepeater Only)
DV-RPTR V1 (USB)
DV-RPTR V2 (USB)
DV-RPTR V3 (USB)
DVAP (USB)
MMDVM / MMDVM_HS / Teensy / ZUM (USB)
STM32-DVM / MMDVM_HS - Raspberry Pi Hat (GPIO)
STM32-DVM (USB)
ZUMspot Libre (USB)
ZUMspot - USB stick
ZUMspot - Single Band Raspberry Pi Hat (GPIO)
ZUMspot - Dual Band Raspberry Pi Hat (GPIO)
ZUMspot - Duplex Raspberry Pi (GPIO)
ZUM Radio-MMDVM for Pi (GPIO)
ZUM Radio-MMDVM-Nucleo (USB)
Note: The Nucleo is for repeater and high power hotspot applications.
MicroNode Nano-Spot (Built In)
MicroNode Teensy (USB)
MMDVM F4M-GPIO (GPIO)
MMDVM F4M/F7M (F0DEI) for USB
MMDVM_HS_Dual_Band for Pi (GPIO)
MMDVM_HS_Hat (DB9MAT & DF2ET) for Pi (GPIO)
MMDVM_HS_Hat Dual (DB9MAT, DF2ET & DO7EN) for Pi (GPIO)
MMDVM_HS_Hat Dual (DB9MAT, DF2ET & DO7EN) for Pi (USB)
MMDVM_HS_AMBE (D2RG HS_AMBE) for Pi (GPIO)
MMDVM_RPT_Hat (DB9MAT, DF2ET & DO7EN) for Pi (GPIO)
MMDVM_HS_MDO Hat (BG3MDO) for Pi (GPIO)
MMDVM_HS_NPi Hat (VR2VYE) for Nano Pi (GPIO)
MMDVM_HS_Hat Dual (VR2VYE) for Pi (GPIO)
LoneStar - MMDVM_HS_Hat for Pi (GPIO)
LoneStar - MMDVM_HS_Dual_Hat for Pi (GPIO)
LoneStar - USB Stick
SkyBridge - MMDVM_HS_Dual_Hat for Pi (GPIO)
MMDVM_NANO_DV (BG4TGO) for NanoPi Air (GPIO)
MMDVM_NANO_DV (BG4TGO) for NanoPi Air (USB)
OpenGD77 DMR hotspot (USB)
Thanks for your help?
What modem is on the Pi Zero WH?
- mikeysklar
Re: What modem is on the Pi Zero WH?
Did you purchase a walkie talkie modem? (DMR, D-STAR, P25, etc.) That is what this is asking. The Pi Zero does not include one by default.
