https://learn.adafruit.com/adafruit-atw ... e-breakout
We're using Kuman UNO, all wires and pins have been checked, however when running the "CheckWiFi101FirmwareVersion" example, all that's output is "WiFi101 firmware check. WiFi 101 Shield: NOT PRESENT". The wires are set up identically to the wires in the guide.
Here's the code we're trying to use
* This example checks if the firmware loaded on the WiFi101
* shield is updated.
* Circuit:
* - WiFi 101 Shield attached
* Created 29 July 2015 by Cristian Maglie
* This code is in the public domain.
#include <SPI.h>
#include <WiFi101.h>
#include <driver/source/nmasic.h>
WiFi.setPins(8,7,4);
// Initialize serial
Serial.begin(9600);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// Print a welcome message
Serial.println("WiFi101 firmware check.");
Serial.println();
// Check for the presence of the shield
Serial.print("WiFi 101 Shield: ");
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("NOT PRESENT");
return; // don't continue
Serial.println("DETECTED");
// Print firmware version on the shield
String fv = WiFi.firmwareVersion();
String latestFv;
Serial.print("Firmware version installed: ");
Serial.println(fv);
if (REV(GET_CHIPID()) >= REV_3A0) {
// model B
latestFv = WIFI_FIRMWARE_LATEST_MODEL_B;
} else {
// model A
latestFv = WIFI_FIRMWARE_LATEST_MODEL_A;
// Print required firmware version
Serial.print("Latest firmware version available : ");
Serial.println(latestFv);
// Check if the latest version is installed
Serial.println();
if (fv >= latestFv) {
Serial.println("Check result: PASSED");
} else {
Serial.println("Check result: NOT PASSED");
Serial.println(" - The firmware version on the shield does not match the");
Serial.println(" version required by the library, you may experience");
Serial.println(" issues or failures.");
// do nothing
