I have an RF69 breakout that I want to use to transmit weather data. I have it paired with an RPI RFM69 bonnet. The boards have short wire antennae. I have my boards sending and receiving packages, but the range is insufficient. When about 30-50' apart they work, but when I move the RPI2040 feather with RFM69 breakout outside, about 60' away and downstairs, the communication breaks down.
My understanding is that these radios shoulld be able to communicate up to 500' or more. I am wondering how much improvement would I gain if I used an applicable antenna? and, do I really need an RF96 board to achieve the 500' more or less? I want my radio to be in my garden to transmit the data from my BME280 sensor. I had it working with BLE but the range was too limited, I could only go from teh deck outside to an RPI zero nearby inside.
Any suggestions would be great. I bought the RFM69 instead fo teh 96 to save $, maybe I will end up spending more $ to save the few I spent.
Roger
rfm69 range
- sj_remington
Re: rfm69 range
A better antenna on both RX and TX would give you much better range, either a 1/4 wave whip perpendicular to a ground plane, or a dipole antenna cut for the proper frequency.
- Rcayot
Re: rfm69 range
Thanks SJ.
I soldered a 3" wire to teh antenna contact, as recommended. I guess the answer is that I should get a pair of tuned antennae, and if they do not provide the range, to go ahead and get teh RFM96 which is higher power trans/rec, where I can re-use the antennae.
Roger
Roger
- sj_remington
Re: rfm69 range
What frequency band is the radio using?
- Rcayot
Re: rfm69 range
I straightened out the antenna, and it seems to have been improved. I will check how far I can go tomorrow.
Roger
Roger
