I am wondering if the Adafruit ESP32-S2 Feather https://www.adafruit.com/product/5000 can be used to trigger actions when it is contacted over WiFi. I have never built anything of this sort before, total newbie here. Lots of software experience, but I'm finding reading the descriptions of this hardware a bit confusing. In my normal computer world I would SSH to a remote server over WiFi and run a script. But this is a microcontroller, so I am a bit at sea.
Please let me know if (A) the Adafruit ESP32-S2 Feather is capable of being triggered over WiFi, and (B) if there is some sample project out there (preferably CircuitPython) that demonstrates how this is done.
Adafruit ESP32-S2 Feather triggered over WiFi?
- mikeysklar
Re: Adafruit ESP32-S2 Feather triggered over WiFi?
Accessing the ESP32-S2 based boards remotely is typically done using WipperSnapper or Adafruit IO.
https://learn.adafruit.com/quickstart-a ... persnapper
https://io.adafruit.com/
So you get your board on WiFi and set it up with a custom AIO key where you can have a web dashboard and read / write sensors / actuators.
- efc
WipperSnapper looks really cool, and I appreciate the pointer. But it looks like an awful lot of overhead, not to mention a dependency on an outside service (AIO) I don't really want.
Isn't there some way I can just tickle my ESP32-S2 Feather directly? If it is on my local network, how can I kick off a process on the microcontroller from another machine on the network over WiFi? If AIO can reach the Feather, then there must be a way for me to reach it directly, no?
- mikeysklar
WipperSnapper is super minimalistic, but I can understand wanting work without depending on the AIO infrastructure.
You can take a look at ampule and WSGI as web server options to run directly on an ESP32-S2 with CircuitPython.
https://github.com/adafruit/Adafruit_CircuitPython_WSGI
https://github.com/deckerego/ampule
It probably makes more sense to go with a plug and play webserver running Arduino code on the ESP32-S2.
https://learn.adafruit.com/esp8266-temp ... he-esp8266
https://randomnerdtutorials.com/esp32-w ... duino-ide/
- efc
Awesome, those are great pointers. Time for me to get dirty and try to build this thing!
- efc
FYI, after purchasing the ESP32S2 Feather I found advice in this thread that helped me use its WiFi successfully... viewtopic.php?f=53&t=186099
