AirLift Shield - ESP32 WiFi Co-Processor loses data connecti
jessr95
Post by jessr95 »
My goal is to upload a file from my SD card on a Teensy 3.6 to a remote FTP server via the Airlift shield.
Currently, it works sometimes but is unreliable. Sometimes it loses the data connection and only partially uploads a file.
Can anyone help?
Thanks in advance!
/* Test code for uploading files to Nova FTP server.
    November 2021
#include <SD.h>
#include <SPI.h>
#include <WiFiNINA.h>
#define server "*****************"
// Teensy 3.6 ESP32 connections
#define SPIWIFI       SPI  // The SPI port
#define SPIWIFI_SS     10   // Chip select pin
#define ESP32_RESETN   35   // Reset pin
#define SPIWIFI_ACK    36   // a.k.a BUSY or READY pin
#define ESP32_GPIO0   -1
// Wifi network details
const char* ssid     = "***********";
const char* password = "************";
const int chipSelect = BUILTIN_SDCARD;  // SD card chip select pin
int status = WL_IDLE_STATUS;
WiFiClient client;
WiFiClient dclient;
char outBuf[255];
char outCount;
byte clientBuf[32];
int clientCount = 0;
unsigned int hiPort, loPort;
File fh;
  Serial.begin(115200);
  while (!Serial);
  // Assign Teensy SPI pins
  // First reassign pin 13 to the default so that it is not SCK
  CORE_PIN13_CONFIG = PORT_PCR_MUX(0);
  // and then reassign pin 14 to SCK
  CORE_PIN14_CONFIG = PORT_PCR_DSE | PORT_PCR_MUX(2);
  // Check for the WiFi module:
  WiFi.setPins(SPIWIFI_SS, SPIWIFI_ACK, ESP32_RESETN, ESP32_GPIO0, &SPIWIFI);
  if (WiFi.status() == WL_CONNECTED) {
    Serial.println(F("Connected to WiFi module."));
  while (WiFi.status() == WL_NO_MODULE) {
    Serial.println(F("Communication with WiFi module failed!"));
    delay(1000);
  // Attempt to connect to Wifi network:
  Serial.print(F("Attempting to connect to SSID: "));
  Serial.println(ssid);
  // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
  do {
    status = WiFi.begin(ssid, password);
    delay(100); // wait until connected
  } while (status != WL_CONNECTED);
  Serial.println(F("Connected to WiFi network."));
  FTP();
  while (1);
byte FTP() {
  Serial.println(F("Initialising SD card..."));
  if (!SD.begin(chipSelect)) {
    Serial.println(F("Initialization failed!"));
    while (1);
  Serial.println(F("Success."));
  // Open data file for reading
  fh = SD.open("DATALOG.txt", FILE_READ);
  if (!fh)
    Serial.println(F("SD open fail"));
    return 0;
  Serial.println(F("File open"));
  // Find the start of the file
  if (!fh.seek(0))
    Serial.println(F("Rewind fail"));
    fh.close();
    return 0;
  // Connect to the server
  Serial.println(F("SD opened"));
  if (client.connect(server, 21)) {
    Serial.println(F("Connected to server"));
  else {
    fh.close();
    Serial.println(F("Command connection failed"));
    return 0;
  if (!eRcv()) return 0;
  client.println(F("USER **********"));
  client.println(F("PASS ***********"));
  client.println(F("SYST"));
  client.println(F("Type I"));
  Serial.println(F("Data connection."));
  client.println(F("PASV"));
  char *tStr = strtok(outBuf, "(,");
  int array_pasv[6];
  for ( int i = 0; i < 6; i++) {
    tStr = strtok(NULL, "(,");
    array_pasv[i] = atoi(tStr);
    if (tStr == NULL)
      Serial.println(F("Bad PASV Answer"));
  hiPort = array_pasv[4] << 8;
  loPort = array_pasv[5] & 255;
  Serial.print(F("Data port: "));
  hiPort = hiPort | loPort;
  Serial.println(hiPort);
  if (dclient.connect(server, hiPort)) {
    Serial.println(F("Data connected"));
  else {
    Serial.println(F("Data connection failed"));
    client.stop();
    fh.close();
    return 0;
//  if (!eRcv()) return 0;
  client.print(F("STOR "));
  client.println(F("DATALOG.txt"));
  if (!eRcv())
    Serial.println(F("Failed writing data."));
    dclient.stop();
    return 0;
  if (!fh.seek(0))
    fh.close();
    return 0;
  while (fh.available()) {
    for (int i = 0; i < 32; i++) {
      int fileData = fh.read();
      while (fileData == -1) {
        Serial.println(i);
        Serial.println(F("SD -1 error"));
        int posFile = fh.position();
        Serial.println(posFile);
        fh.close();
        Serial.println(F("File close"));
        delay(1000);
        fh.seek(posFile);
        Serial.println(fileData);
      clientBuf[clientCount] = byte(fileData);
      clientCount++;
    if (clientCount > 1)
      size_t checkWrite = dclient.write(clientBuf, 32);
      if (checkWrite == 0) {
        Serial.println(F("Fatal FTP Error!"));
        if (!dclient.connected()) {
          Serial.println("Disconnected");
        dclient.stop();
        dclient.connect(server, hiPort);
        return 0;
      if (checkWrite != 32 && checkWrite > 0) {
        int pointer = checkWrite;
        delay(100);
        dclient.write(clientBuf + pointer, 32 - pointer);
      clientCount = 0;
  if (clientCount > 0) {
    dclient.write(clientBuf, clientCount);
  dclient.stop();
  return 1;
byte eRcv()
  byte respCode;
  byte thisByte;
  delay(400);
  while (!client.available()) {
    delay(1);
  respCode = client.peek();
  outCount = 0;
  while (client.available())
    thisByte = client.read();
    Serial.write(thisByte);
    if (outCount < 254)
      outBuf[outCount] = thisByte;
      outCount++;
      outBuf[outCount] = 0;
  if (respCode >= '4')
    efail();
    return 0;
  return 1;
void efail()
  byte thisByte = 0;
  client.println(F("QUIT"));
  while (!client.available()) delay(1);
  client.stop();
  Serial.println(F("Command disconnected"));
  fh.close();
  Serial.println(F("SD closed"));
Return to “Wireless: WiFi and Bluetooth”
