First of all sorry for late reply. If you don't mind can you explain what you mean by BLE can work work on only one channel at a time. And can you please give some information how I can connect the adafruit Bluefruit sniffer with J-Link Segger. I can't make sense how I can connect so flash the firmware. Any help would be grateful.adafruit2 wrote:we dont think so - we do know that the channel for BLE can be 1 to 3 and the sniffer only works on one channel at a time - not sure if that is relevant
Can't capture packets using Bluefruit LE Sniffer - nRF51822
- _jeet_rami_
Re: Can't capture packets using Bluefruit LE Sniffer - nRF51
- adafruit2
the bottom 4 pads are labeled on the sniffer for the 4 JLINK connections. you will need to match the wires up and then use nrfjprog or similar. we don't have the instructions for the firmware you've got but you can look up to see what we used for the current firmware. see https://learn.adafruit.com/introducing- ... aq-2317992 for more
see https://learn.adafruit.com/introducing- ... aq-2317991 for the other question
