wipe the non-Volatile memory on the nrf52840 chip
- willwade
Ive managed to write some data to the nrf52840 no-volatile memory - which is great. The only thing is I was wondering about a nifty trick of deleting this. Any suggestions? (Im on a feather express by the way)
- mikeysklar
Re: wipe the non-Volatile memory on the nrf52840 chip
Are you coding in Arduino or CircuitPython? Can you post an example of the NVRAM code you are using?
- willwade
- mikeysklar
There is a public method called "remove" to takeout the file.
https://github.com/adafruit/Adafruit_nR ... leFS.h#L58
- willwade
OK. Im really stupid so apologies..
If I add a function say this..
I get a
Am I calling that function you note correctly??
void delete_devList(void)
Serial.println("at+deletedevlist");
file.delete(FILENAME);
Serial.println("SUCCESS. Now turn on and off. ");
expected unqualified-id before 'delete'
- mikeysklar
Wouldn't it be remove as opposed to what you tried which was delete?
// Delete the file.
bool remove (char const *filepath);
- willwade
:facepalm: You know when you look at something like 30 times.. and then again just before posting...
And I couldn't see that for the life of me. I really am stupid..
Thanks :embarrassed:
- mikeysklar
@willwade,
It find it hard to keep the terminology straight as well. There are many implementations of littlefs and they each seem to use their own erase, delete or remove solutions.
Were you able to get working code? If so feel free to share it here.
