Linux won't find CPB
Insert_Name_Here
Post by Insert_Name_Here »
I have a circuit playground bluefruit.
On windows and my dad's mac book it works.
But it wont work on linux.
from adafruit_circuitplayground import cp
from adafruit_ble import BLERadio
from adafruit_ble.advertising.standard import ProvideServicesAdvertisement
from adafruit_ble.services.standard.hid import HIDService
from adafruit_ble.advertising import Advertisement
from adafruit_hid.mouse import Mouse
cp.pixels.brightness = 0.1
cp.pixels.fill((0, 0, 0))
ble = BLERadio()
hid = HIDService()
advertisement = ProvideServicesAdvertisement(hid)
scan = Advertisement()
scan.complete_name = "Circuit Playground BLE"
mouse = Mouse(hid.devices)
while True:
    ble.start_advertising(advertisement, scan)
    cp.pixels.fill((0, 50, 50))
    while not ble.connected:
        pass
    while ble.connected:
        cp.pixels.fill((0, 50, 0))
        while cp.button_a:
            mouse.click(Mouse.LEFT_BUTTON)
        while cp.button_b:
            mouse.click(Mouse.RIGHT_BUTTON)
dastels
Re: Linux won't find CPB
Post by dastels »
You say it won't find it and that it doesn't work. What exactly do you mean? The CIRCUITPY drive is not mounting? If you double reset when connected to the Linux box does the BOOT drive mount?
There might be some useful information in this thread: viewtopic.php?f=57&t=186172&p=902512.
Insert_Name_Here
No. I mean linux won't connect to it via bluetooth.
dastels
Post by dastels »
Ah. I'm afraid I can't help, but I'll make sure this gets seen someone who can.
Insert_Name_Here
Thanks.
adafruit2
Post by adafruit2 »
gotta make sure - do you have BLE support hardware in the linux box or just BT classic?
Insert_Name_Here
Linux "box"?
Claude_J_Greengrass
Post by Claude_J_Greengrass »
Insert_Name_Here wrote:Linux "box"?
box == computer e.g. Computer that is running Linux
Insert_Name_Here
This computer also runs windows, and it works on there. So...
danhalbert
Post by danhalbert »
Try this slight variant on your program. Note the supervisor.disable_ble_workflow() at the top. Also I changed how to set the advertising name, which may not make any difference.
import supervisor
ble = BLERadio()
ble.name = "Circuit Playground BLE"
hid = HIDService()
while True:
    ble.start_advertising(advertisement)
        pass
    print("connected")
        while cp.button_a:
        while cp.button_b:
You must pair with Linux before HID will work. I scanned for the device and then paired with it.
You can erase old pairing/bonding info by doing this in the REPL:
>>> import _bleio
>>> _bleio.erase_bonding()
You don't need to do this every time.
I have found you often have to turn Linux Bluetooth off and then back on again if some error has occurred.
Insert_Name_Here
import supervisor
ble = BLERadio()
hid = HIDService()
while True:
        pass
    print("connected")
        while cp.button_a:
        while cp.button_b:
results in red blinking neopixels.
danhalbert
Please look at the serial output to see what the errors are.
Insert_Name_Here
The circuit python REPL in mu says:
Adafruit CircuitPython 7.0.0 on 2021-09-20; Adafruit Circuit Playground Bluefruit with nRF52840
>>> uto-reload is on -
Not anything to do with an error.
danhalbert
Type ctrl-D at the REPL prompt. That will restart code.py. Then see if you see an error.
Insert_Name_Here
Still the same output.
Return to “Wireless: WiFi and Bluetooth”
