mac-adress of circuit playground bluefruit?
- bjoarnae
I wonder uif there are some way of finding each circuit playground bluefruit board mac-adress via bluetooth connection?
- bjoarnae
Re: mac-adress of circuit playground bluefruit?
Or alternatively: how can I connect more than two cpb's, using one as master and the other one's as slave - without having some spesific different addresses to use?
- danhalbert
When a board running CircuitPython does a BLE advertisement, by default it advertises with the name "CIRCUITPYnnnn", where nnnn is the last four hex digits of the BLE address. You can also set the name by doing something like:
So the central doing the advertising scanning can check the name.
The address is also available as `ble.address_bytes`.
ble = BLERadio()
ble.name = "NewName"
- bjoarnae
Thank you a lot danhalbert! Exellent! just what I need. I gues that since the name of each cpb can be changed (the first part, before nnnn) I can do that to more easily seperate the different cpb's.
Best regards Bjorn Arne
- danhalbert
You can change the name to anything; the nnnn is not preserved or required: it just appends that to CIRCUITPY to make it semi-unique.
