i am not able to bootload my HUZZAH esp8266 breakout board and i have no idea why
im using this USB to TTL converter https://www.otronic.nl/a-61052754/serie ... r-3-3v-5v/
but i cant bootload it with arduino nor ESPhome witch i want to use it for
HUZZAH esp8266 not able to bootload
- adafruit_support_carter
Re: HUZZAH esp8266 not able to bootload
Just to check, you're using one of these?
https://www.adafruit.com/product/2471
Are you following this guide for Arduino setup?
https://learn.adafruit.com/adafruit-huz ... rduino-ide
- SuperFLERB
yes im using that board and setup
- Hold down the GPIO0 button, the red LED will be lit
- While holding down GPIO0, click the RESET button
- Release RESET, then release GPIO0
- When you release the RESET button, the red LED will be lit dimly, this means it's ready to bootload
- SuperFLERB
yes the red led stays dimly lit
OK, sounds like bootloader is generally working. It's a ROM bootloader, so is essentially impossible to break.
What happens if you select the COM port for your USB/TTL convert and attempt to upload Blink?
https://learn.adafruit.com/adafruit-huz ... 2571087-23
- SuperFLERB
this is what happens
- Schermafbeelding 2022-03-10 202650.png (50.76 KiB) Viewed 128 times
Please post a photo of your setup showing how the USB/TTL cable is attached to the HUZZAH.
- SuperFLERB
i here have the picture in a discord link becouse the size was too big
https://cdn.discordapp.com/attachments/ ... 204839.jpg
Swap TX/RX wires on one end.
HUZZAH TX should go to USB/TTL RX
HUZZAH RX should go to USB/TTL TX
- SuperFLERB
i now have this error
- Schermafbeelding 2022-03-10 222619.png (83.1 KiB) Viewed 118 times
See here for esptool troubleshooting:
https://docs.espressif.com/projects/esp ... oting.html
Is the problem repeatable?
Power is mentioned as a possible cause. Make sure the soldering on the V+ pin is good.
- soldering.jpg (21.84 KiB) Viewed 105 times
- SuperFLERB
well i plugged a wire in both v+ and the red led started blinking
but trying to bootload diffrent code (delaytime changed) and i get the errors again
- SuperFLERB
nevermind i had the com port still open in another window
thanks for the help
thanks for the help
- SuperFLERB
How do i bootload a diffrent .bin file to the huzzah? Becouse the site from esphome cant connect to it and niether can a diffrent espflasher i have installed
