hello,
I used python 2.7.13 and Adafruit_Adalink project [https://github.com/adafruit/Adafruit_Adalink] for readind mac id of NRF52 controller on window 10 by execuiting command "adalink nrf52832 --programmer jlink --info".
Now my window is updated to window 11 when i try to install python 2.7.13 and Adafruit_Adalink there is issue in step no 6 as given below.
i have done the following process for installation
1.install Python 2.7.13.
2.add their path to environment variable
3.run python command to check proper installation
4.download Adafruit_Adalink project file
5.unzip in python 27 folder
6.then run python setup.py install command
obtained response is
Adafruit_Adalink project installation
- nikita_k
- Attachments
- issue2.png (243.74 KiB) Viewed 135 times
- rpiloverbd
Re: Adafruit_Adalink project installation
Have you tried on python 3?
- nikita_k
Yes, I have tried with python 3.10.2
I think it is installed
but when I give following command to read MAC ID following response obtained which I am not understanding
command is "adalink nrf52832 --programmer jlink --info".
- Attachments
- issue3.png (50.25 KiB) Viewed 101 times
- issue4.png (82.98 KiB) Viewed 101 times
- adafruit2
yeah adalink isnt maintained anymore. but, there's also a much better tool now from nordic called 'nrfprog' which works on any platform with a jlink so you can use that instead!
- nikita_k
I used nrfprog also but using these i can get MAC address of nrf development board but unable to get mac address of my custom board.
