In file included from G:\arduino-1.8.19\portable\sketchbook\libraries\Adafruit_IO_Arduino\src/AdafruitIO_WiFi.h:26,
from G:\arduino-1.8.19\portable\sketchbook\PortalM4_IO_sketch\config.h:36,
from G:\arduino-1.8.19\portable\sketchbook\PortalM4_IO_sketch\PortalM4_IO_sketch.ino:19:
G:\arduino-1.8.19\portable\sketchbook\libraries\Adafruit_IO_Arduino\src/wifi/AdafruitIO_AIRLIFT.h: In member function 'void AdafruitIO_AIRLIFT::setLEDs(uint8_t, uint8_t, uint8_t)':
G:\arduino-1.8.19\portable\sketchbook\libraries\Adafruit_IO_Arduino\src/wifi/AdafruitIO_AIRLIFT.h:110:56: error: 'class WiFiClass' has no member named 'setLEDs'
110 | void setLEDs(uint8_t r, uint8_t g, uint8_t b) { WiFi.setLEDs(r, g, b); }
G:\arduino-1.8.19\portable\sketchbook\libraries\Adafruit_IO_Arduino\src/wifi/AdafruitIO_AIRLIFT.h: In member function 'virtual void AdafruitIO_AIRLIFT::_connect()':
G:\arduino-1.8.19\portable\sketchbook\libraries\Adafruit_IO_Arduino\src/wifi/AdafruitIO_AIRLIFT.h:176:14: error: 'class WiFiClass' has no member named 'setPins'
176 | WiFi.setPins(_ssPin, _ackPin, _rstPin, _gpio0Pin, _wifi);
Multiple libraries were found for "Adafruit_ZeroDMA.h"
Used: G:\arduino-1.8.19\portable\packages\adafruit\hardware\samd\1.7.10\libraries\Adafruit_ZeroDMA
Not used: G:\arduino-1.8.19\portable\sketchbook\libraries\Adafruit_Zero_DMA_Library
exit status 1
Error compiling for board Adafruit Matrix Portal M4 (SAMD51).
If I then enable WINC1500, the code does compile, but the device fails to connect to WiFi.
