I took the BLE code and brought it into my scrolling MatrixPortal M4 code.
I am getting a conversion error and do not know how to address it.
def read_ble():
while ble.connected:
# Returns b'' if nothing was read.
one_byte = uart.read(1)
if one_byte:
uart.write(one_byte)
print(one_byte,"during read function")
return one_byte
adv_ble() >>>>>>>>>>>>>>>>>>>>>> advertise
print("next is read-ble")
bytes_in = read_ble() >>>>>>>>>>>>>>>>>>>>>>>>read
line1 = adafruit_display_text.label.Label(
terminalio.FONT,
color=0xff0000,
text= bytes_in) #one_byte) >>>>>>>>>>>>>>>>>>>> line 94
line1.x = display.width
line1.y = 8
I get this detail in terminal mode.
b'a' during read function
b'a' after function >>>>>>>>>>>> this is from my iphone Connect app
File "code.py", line 92, in <module>
File "adafruit_display_text/label.py", line 90, in __init__
File "adafruit_display_text/__init__.py", line 270, in __init__
File "adafruit_display_text/__init__.py", line 345, in background_color
File "adafruit_display_text/label.py", line 189, in _set_background_color
TypeError: can't convert 'str' object to bytes implicitly
Can someone advise me what is causing the error?
Bob
- Rebtop
- Rebtop
Re: TypeError: can't convert 'str' object to bytes implicitl
I want to delete the original post.
After a lot of searching, i found what i needed. It is the encode statement in the sample code.
The problem now is it will only allow numberics. Error SyntaxError('invalid syntax',)
Can i get an idea how to fix this?
def read_ble():
s = uart.readline()
if s:
try:
result = str(eval(s))
except Exception as e:
result = repr(e)
uart.write(result.encode("utf-8"))
return result
def read_ble():
s = uart.readline()
if s:
try:
result = repr(e)
return result
- Rebtop
K
This is the BLE read function
def read_ble():
s = uart.readline()
if s:
try:
result = repr(e)
return result
When i enter numerics without spaces, it works. The display scrolls the numbers.
But when i enter alpha characters, i get this error
>>>>>>>>>>>>>>>>>> NameError("name 'a' is not defined",) after function >>>>>>>>>>>> this is from my Iphone with Connect
Different then first error.
def read_ble():
s = uart.readline()
if s:
try:
result = repr(e)
return result
- Rebtop
OK
How do i receive Alpha characters? Not just numeric?
The code is your sample, slightly modified, BLE UART on your site.
Than
Than
- Rebtop
eval() is numeric only...............
Got it!
Got it!
- neradoc
It's more that "eval" evaluates the string as code. So if the string is "hello", it will try to evaluate a variable named hello.
I believe what you want is to convert the bytes into a string with decode().
You can show your full code too if you want someone to look at it.
(note: Format your code with the "code" button/tags or all indentation is lost).
def read_ble():
s = uart.readline()
if s:
result = s.decode("utf8")
uart.write(s)
return result
return ""
- Rebtop
It worked.
I spent too much time trying different code and it turns out this was a simple solution..
Thank you very much for your help.
Bob
Bob
