There is a forum thread on pjrc: https://forum.pjrc.com/threads/70062-Te ... ng-Port-21
Where a user was having an issue.... So thought I would try it out. I don't have the Feather wing, but do have an Airlift Wifi Breakout, that I purchased two years ago....
I believe it is a: https://www.adafruit.com/product/4201
Although the dot on mine is pink not blue...
So figured I probably need to update the firmware. I have been trying using stuff on: https://learn.adafruit.com/adafruit-air ... t-firmware
Note: I am trying to update using a Teensy 4.1...
So far I have not had any luck:
Note: the program on that page does not compile as confusion on PIN_NEOPIXEL versus NEOPIXEL_PIN
Also does not make sense to me, as some of the instructions talk about GPIO0 and like the fetherwing talks about SJ.... But sketch shows -1 pin number for this?
So far the ESP tool has not wanted to talk to the ESP32... I tried connecting it to a pin and update sketch to that pin. Tried simply connecting to 3.3v or gnd, still does not talk.
Any suggestions?
Update firmware on ESP32 Airlift Wifi breakout
- mjs513
Re: Update firmware on ESP32 Airlift Wifi breakout
I have been having the same problem but in my case I am using a Adafruit Featherwing.
I soldered up the three pads under the board per the instructions on: https://learn.adafruit.com/adafruit-air ... t-firmware.
Then I loaded up the passthrough sketch but also noticed that for the Teensy gpio0 is set to -1 instead of 10 so not sure how you get it into bootloader mode if set to -1:
With that said if I run the sketch I do see this in the serial monitor:
With that said I have tried to update the uf2 but I can't seem to get it to go into bootloader with the double clip - spent a good half hour trying. So ditto to what @KurtE said
// manually put the ESP32 in upload mode
digitalWrite(ESP32_GPIO0, LOW);
digitalWrite(ESP32_RESETN, LOW);
delay(100);
digitalWrite(ESP32_RESETN, HIGH);
ets Jul 29 2019 12:21:46
rst:0x1 (POWERON_RESET),boot:0x2 (D
