Bluefruit Friend Sleep Mode
kostathan
Post by kostathan »
Hi all!
I am trying to create a module that transfers the data from a CO2 sensor to my cell phone. I've already managed to send the data to my cell phone via the Bluefruit UART Friend and at this stage, I am trying to manage the power consumption of the device.
For my application, a CO2 sensor measurement is needed every 3-5 minutes, so its quite wasteful to use the BLE all this time. I'd like to know how I can reduce the consumption by putting the BLE into sleep mode and how can I wake it up.
Is the command mode more power-friendly? If so, what is the consumption in command mode? Are there any commands that induce sleep mode?
Thank you in advance.
mikeysklar
Re: Bluefruit Friend Sleep Mode
Post by mikeysklar »
On BLE Friend firmware 0.7.0 and higher you have low power advertising.
>= 0.7.0: Low power advertising interval (in milliseconds), default = 417.5 ms
To save power, the Bluefruit modules automatically drop to a lower advertising rate after 'fast advertising timeout' seconds. The default value is 30 seconds ('Fast Advertising Timeout'). The low power advertising interval is hard-coded to approximately 0.6s in firmware < 0.7.0. Support to control the low power interval was added in the 0.7.0 firmware release via an optional fifth parameter.
Please note the following min and max limitations for the GAP parameters:
Absolute minimum connection interval: 10ms
Absolute maximum connection interval: 4000ms
Absolute minimum fast advertising interval: 20ms
Absolute maximum fast advertisting interval: 10240ms
Absolute minimum low power advertising interval: 20ms
Absolute maximum low power advertising interval: 10240ms
https://learn.adafruit.com/introducing- ... d?view=all
Return to “Wireless: WiFi and Bluetooth”
