use rfm9x gpio pins from circuitpython?
Rcayot
Post by Rcayot »
Sometimes is is convenient to reset my PICO running my weather station remotely.
I was wondering if I could use one of the RFM9x breakout boards gpio pins to reset the pico. I am using circuit-python, and none of the documentation comments on how to use those. What I was thinking was that I could send a command via REPL to pull a gpio pin low connected to the 'run' pin on the PICO.
Roger
mikeysklar
Re: use rfm9x gpio pins from circuitpython?
Post by mikeysklar »
Roger,
I can see why you would want the remote reset ability for hangs, etc.
The RP2040 does support the CMSIS functions so you can also consider trigger reset in your code via REPL console.
; soft reset
import supervisor
supervisor.reload()
; hard reset
import microcontroller
microcontroller.reset()
Rcayot
Post by Rcayot »
Thanks Mike.
I think if I cannot use the RFM9x GPIO, (probably need to be running Arduino code for that), then I could use a button. I would like to have a local display to output the serial port to, but the low power ones, like e-ink, are likely too slow to keep up with serial out, except or unless I disable all my debugg 'prints'. Which is no problem.
I will investigate if micropython has a port of the radiohead library.
Roger
mikeysklar
Roger,
Looking through the rfm9x (CircuitPython library) I don't see GPIO controls. There is a reset() function for the radio only, but not for the CircuitPython board that is connected to it.
https://github.com/adafruit/Adafruit_Ci ... t_rfm9x.py
What I like to do when I'm doing remote development and need to have a REPL console and way to reset the microcontroller is use a Pi Zero and connect your controller to the USB port. Then you can do all the development over ssh / CLI. The only downside in your case is it sound as though you have a power constraint.
Return to “Wireless: WiFi and Bluetooth”
