I'm teaching a class where we have 26 students each with their own CPB. I want to show them how to connect their phone to the CPB using the Connect App. The sample code provided online works extremely well when I connect to my own device. But when I'm in a room with 26 others who are also running code making their devices available over Bluetooth it's impossible to tell which device belongs to whom!
My question is if there is a name a user can assign to their particular CPB's that shows up when it is advertising to be connected. For example, I might like to be "MeierCPB".
I hope that made sense. Thanks in advance.
Mark
Circuit Playground Bluefruit BLE Advertising Name
- mkmra2
- neradoc
Re: Circuit Playground Bluefruit BLE Advertising Name
Hi, what programming environment are you using ?
If using Circuitython, the default name can not be changed currently (though it would be interesting to change that with .env), but when the user code is using BLE you can change the name it advertises as. This should change the name by which the board is seen externally, but some devices might cache the name of a paired device and require to forget the device before the new name is seen.
For example:
For example:
ble = BLERadio()
ble.name = "My BLE board"
- mkmra2
Thanks for the reply. We are using CircuitPython 7.3.1 and Mu.
It works nicely. Thanks very much!
Mark
Mark
