Bluefruit EZ-link operational temperature range
by sfleming144 on Mon Sep 01, 2014 3:38 pm
What is the operational temperature range of the Bluefruit EZ-link break out board? I plan on using it in a weather station that will be mounted in a protected enclosure outdoors.
sfleming144
Re: Bluefruit EZ-link operational temperature range
by adafruit2 on Tue Sep 02, 2014 1:21 pm
We don't have formal temperature grading, but 0-70 *C should be fine as that's standard commercial grade. wider ranges may work, experimentation is key :)
Watch out for humidity/dew, that can really be an issue if you have temp cycling
adafruit2
Site Admin
by sfleming144 on Tue Sep 02, 2014 2:20 pm
I hope it can work below 0 degrees Celsius, since it can go below 0 degrees Fahrenheit here in the winter(thankfully not very often!). If it does not, I will need to use another Bluetooth module.
sfleming144
