Help! Two Bluefruit EZ-Links that will not show serial ports
by sdtrent on Mon Sep 15, 2014 3:32 pm
Last week I ordered a USB 4.0 dongle and two Bluefruit EZ-Link modules to set up wireless programming of an Arduino Pro Mini on my Windows 7 Pro 64-bit PC. Everything went fine through pairing until I checked the property of the EZ-Link under "Devices and Printers". The Hardware tab shows no serial ports under Device Functions. There is nothing showing under Services either. I have tried multiple re-installs of both the USB dongle and the EZ-Link modules with the same results each time.
I decided to test them on a Mac Mini. Oddly enough, one module would pair and one never showed up. On the Mac the first module paired and I was able to program the Arduino Pro Mini. But the second EZ-Link module never showed up on the Mac's bluetooth even after multiple attempts of holding down the pairing button for 5 sec to reset the pairing. When I started testing I was using a Li-ion battery (18650) for power (final application will be battery powered) but switched to a regulated 3.3V supply when I began having trouble. I tried multiple PC restarts and installed the latest Windows updates.
Any suggestions on getting the modules to work on my Windows 7 PC? I want to write a program to provide a UI on the PC for controlling the Arduino outputs and would like to avoid the steep learning curve of learning programming on the Mac.
Thank you for your help,
Shane
sdtrent
Re: A Tale of Two Bluefruit
by sdtrent on Tue Sep 16, 2014 11:02 am
Still trying to get the Bluefruit EZ-Link to work on my Windows 7 PC. Is it possible to connect to the Bluefruit EZ-Link through a FTDI cable and initiate a pairing from the Bluefruit EZ-Link module? This has been suggested for pairing diagnostics on Windows 7.
Shane
sdtrent
Re: Help! Two Bluefruit EZ-Links that will not show serial p
by sdtrent on Wed Sep 17, 2014 11:31 am
It appears the missing serial port on the Bluefruit EZ-link module is due to an issue with my Windows 7 desktop. Both EZ-link modules work fine on another Windows 7 PC. Would still appreciate any advice on fixing the Bluetooth on Windows 7 but suspect a clean install wold be required.
Shane
sdtrent
