inductive charging problems
by Addman on Wed Sep 24, 2014 11:40 pm
I got the Inductive Charging Set (5V @ 500mA max) for a phone charging projects. after reading the tutorial and some forum post on the subject. i first tied the charger on a 9v battery and led red, which glowed fine but wouldn't power my phone(A Nexus 5) when i tried. i measure the output of the charger and got ~5v. I surmised the 9v battery just wasn't sufficient so I tested with a wall adapter (12v 500mA). but the chip got hot i unplug it immediately but i think i fried the chip. was i out of spec ? if so how much would you recommend powering the transmitter?
Addman
Re: inductive charging problems
by adafruit_support_bill on Thu Sep 25, 2014 6:28 am
It is rated for 9-12v DC (If using a wall adapter, make sure that the output is regulated DC. Some are AC, or sometimes just rectified AC.)
Keep in mind that these are only about 40% efficient. So to get 5v@500mA (2.5W) out to charge a phone, you need to put 6.25 watts in. At 12v, that would be about 550mA. All that excess power has to go somewhere. So it gets dissipated as heat.
by Addman on Thu Sep 25, 2014 2:21 pm
How would u suggest displacing that heat. Could i use a heat sink?
Addman
by adafruit_support_bill on Thu Sep 25, 2014 2:39 pm
Not sure about these, but most power components can tolerate pretty high operating temperatures. But a heatsink never hurts. We have some small ones - and some thermal adhesive tape to go with them in the store.
by Srinivasa on Tue Sep 30, 2014 7:41 pm
Recently we purchased 10x mini Heat sink #1515 and we are interested using the same , However we did not much Information form your website such as ,
RoHS and also manufacture details. Is it possible to provide Techincal information along with RoHS and Manufacture details for documentation ?
Regards,
Srinivasa Govndha
Srinivasa
by adafruit on Wed Oct 01, 2014 12:56 pm
we will request this.
cheers,
adafruit support
