nRF8001 Bluefruit board set different name
by slider on Mon Sep 29, 2014 7:00 am
I would like to change the name that nRF8001 uses to do the advertising, but i can't find any function to do it.
slider
Re: nRF8001 Bluefruit board set different name
by adafruit_support_rick on Mon Sep 29, 2014 10:43 am
by slider on Mon Sep 29, 2014 10:50 am
I need to do it in the setup function in the arduino sketch.
slider
by adafruit_support_rick on Mon Sep 29, 2014 11:14 am
You can't do it there. It's a firmware thing.
by slider on Mon Sep 29, 2014 11:41 am
The library from RedBearLab (board with the same nRF8001) has a function to do it: https://github.com/RedBearLab/nRF8001/b ... _nRF8001.h
slider
by franklin97355 on Mon Sep 29, 2014 3:41 pm
Could you modify their library to do what you want?
franklin97355
by adafruit_support_rick on Mon Sep 29, 2014 4:06 pm
Our nRF8001 engineer is looking into this.
by adafruit_support_rick on Tue Sep 30, 2014 1:06 pm
OK, we just pushed up a new version of the library:
I just pushed an update that adds a new (optional) .setDeviceName function. You can set a name up to 7 characters long instead of the default "UART" (that's all the space we have in the advertising packet). Sending more than 7 characters will return without taking the changes into affect.
This needs to be called before the device is initialised, so I added it at the appropriate place in both the echoDemo and callbackDemo examples
https://github.com/adafruit/Adafruit_nRF8001
by slider on Tue Sep 30, 2014 1:14 pm
Thank you Rick
slider
by aschaper on Tue Sep 30, 2014 1:28 pm
Thanks Rick, this is awesome!
aschaper
