Programming ESP8266
Programming ESP8266
by dtw on Sun May 10, 2015 12:25 pm
I am having trouble programming my new HUZZAH ESP8266 breakout boards (product id: 2471). I bought two - and I have attempted to send Arduino code to one of them. It fails for various reasons. Most often I get 'warning: espcomm_sync failed error: espcomm_open failed' and 'espcomm_open failed "http://downloads.arduino.cc/packages/package_index.json file signature verification failed. File ignored.'
I have a Mac and I downloaded the latest Arduino IDE - 1.6.4. I used the "Tools/Board Manager" to load the latest Adafruit ESP8266 board (version 1.6.2.) which includes Generic ESP8266 and Adafruit HUZZAH ESP8266 boards.
I am using the Adafruit "USB to TTL Serial Cable - Debug / Console Cable" - which works with the ESP8266 running LUA. On my Mac the serial port is identified as "tty.usbserial".
In the Arduino IDE I select the board as "Adafruit HUZZAH ESP8266" and the port as "tty.usbserial". Prior to updating to version 1.6.2 of the Adafruit board manager, I also selected the "Tools/Programer" menu to select a special programmer. That option went away when I updated to version 1.6.2, so I do not select anything in that option.
On the ESP8266 board I have put it into program mode, pressing the GPIO0 button while also pressing Reset. The board now has the red led lighted as a dim glow. That does not change when the board is powered down and restarted. In fact, the board seems to be only in that mode. If I press the Reset button only the blue LED flashes.
I have restarted the computer, the IDE and the HUZZAH board, and I have made sure there are no other programs attempting to use the tty.usbserial port.
For the Adafruit "USB to TTL Serial Cable - Debug / Console Cable(product id: 954), in the Mac SYSTEM INFORMATION program, the usb port shows the following info:
Product ID: 0x2303
Vendor ID: 0x067b (Prolific Technology, Inc.)
Version: 3.00
Speed: Up to 12 Mb/sec
Manufacturer: Prolific Technology Inc.
I am hoping someone can give me suggestions on how to get this working. I am curious if anyone has gotten the HUZZAH board working with Arduino IDE on a Mac, So far every effort has failed.
David
dtw
Re: Programming ESP8266
by adafruit_support_rick on Mon May 11, 2015 9:42 am
Please post pictures showing your soldering
by adafruit2 on Mon May 11, 2015 11:08 am
yah this is unusual, it suggests theres something amiss with the console cable connection. can you follow the nodemcu tutorial (connect to and communicate with Lua)?
adafruit2
Site Admin
by dtw on Mon May 11, 2015 12:11 pm
dtw
by adafruit2 on Mon May 11, 2015 12:28 pm
looks good, can you follow the nodemcu tutorial (connect to and communicate with Lua)?
adafruit2
Site Admin
by dtw on Mon May 11, 2015 12:37 pm
I am unsure. Now that I have attempted to load Arduino code into the ESP8266, how do I reset the breadboard so it works as nodemcu? Right now, when I plug the ESP8266 into the USB serial connections - the onboard red LED comes on but dim. If I press RESET the LED goes off, but when I let go, it goes back to dim. If I press GPIO0 the LED comes on bright for as long as I hold the button.
dtw
by dtw on Mon May 11, 2015 12:39 pm
That should have said " how do I reset the breakout board"
dtw
by adafruit2 on Mon May 11, 2015 12:40 pm
sounds like nodemcu firmware got deleted...
OK hold down GPIO0, then click the reset button, then release GPIO0
Then try re-programming via the Arduino IDE, post up the error messages you get. dont forget to select the correct USB port :)
adafruit2
Site Admin
by dtw on Mon May 11, 2015 12:48 pm
Held down GPIO0, click the reset button, then release GPIO0.
After resetting the breakout - the red LED still glows dimly.
Attempted to upload the basic Blink sketch. Message displayed:
Sketch uses 191,616 bytes (36%) of program storage space. Maximum is 524,288 bytes.
dtw
by dtw on Mon May 11, 2015 1:00 pm
I am using an upload speed of 9600. Is that OK?
dtw
by adafruit2 on Mon May 11, 2015 1:33 pm
upload speed should be 115200
can you post a screenshot of your board menu setup?
adafruit2
Site Admin
by dtw on Mon May 11, 2015 1:49 pm
At 115200 I got the following messages when I tried to upload the sketch:
Sketch uses 211,244 bytes (40%) of program storage space. Maximum is 524,288 bytes.
Uploading 36528 bytes from /var/folders/0r/fg_v_h5160j8zqp8t_kjt0yh0000gn/T/build496421989369284756.tmp/HelloServer.cpp_00000.bin to flash at 0x00000000
error: failed reading byte
warning: espcomm_cmd: cant receive slip payload data
warning: espcomm_send_command(FLASH_DOWNLOAD_BEGIN) failed
dtw
by dtw on Mon May 11, 2015 1:51 pm
I got the previous error message was when I was trying to load a bigger sketch - the demo HelloServer sketch.
When I tried to load Blink I got:
dtw
by adafruit2 on Mon May 11, 2015 2:03 pm
ok closer! that port selection is weird, can you show the submenu?
adafruit2
Site Admin
by dtw on Mon May 11, 2015 2:23 pm
dtw
